Sending Faxes
I am using VG (4 line license) with a Dialogic D4/PCI but only using 2 lines. Would it be possible to use one of the other lines (of the software) to control a fax modem so that under certain circumstances, the script could send a fax?
To make this clear, the D4/PCI would answer a voice call, the caller would enter dtmf tones and subject to criteria being met, a fax would be output on another line (line 3) but using a fax modem rather than the dialogic card
Please see some examples in the VG Help file's section on "Run VB Script" module.
That section contains information on how to send faxes from VG using WinFax.
