telecom5 Report post Posted 03/06/2003 05:50 PM I am a new user, and I have built my scripts and they are working fine. The one issue that I can't seem to resolve is that once I transfer a call, upon return if the caller isn't available, the main greeting script plays once again. I have tried to set the time out and fail path to got to the voicemail box but it doesn't work. I am wondering if i have not added a proper path upon return? Do I need to get a Call route file set up on one of my 4 lines to act as a VMail box for these returning calls? I have looked thru most of the help fields, and cannot figure this out. Thanks! Share this post Link to post
SupportTeam Report post Posted 03/06/2003 09:43 PM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
telecom5 Report post Posted 03/06/2003 11:50 PM I am new to this so if I am missing something fairly obvious I am sorry. One the message gets transfered to the extention, if there is no answer then it comes back and hits the main greeting again. Event Trace Log 29516 5 tapie linedevstate 2048 0 0 29546 5 tapie callstate OFFERING 65711 0 4 29546 5 Answer the call 29566 5 lineAnswer(65711) => 65830 29566 5 tapie callinfo CALLEDID 29566 5 tapie callinfo ORIGIN 29566 5 tapie ring 0 30107 5 tapie callstate CONNECTED 65711,1,0 30107 5 WorkingModeTAPI= 30107 5 WorkingModeScript= 30137 5 tapi Reply 65830 0 30137 5 tapie callinfo MONITORMODES 30137 5 TimeoutClear 30137 5 [Main Greeting] Number Input 30157 5 [Main Greeting] Playing (vmailrec.wav) 31609 5 PlaySoundStart ok [F:\VoiceGuide\Scripts\vmailrec.wav] 31609 5 TimeoutClear 31619 5 wa(25087,33015700) 31649 5 tapie callinfo MONITORMODES 31659 5 tapie callinfo MONITORMODES 56775 5 Play End line[5] (id=330157) 56805 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 56805 5 TimeoutSet 10 EV_TIMEOUT_HANGUP 56805 5 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 56956 5 tapie monitordigits 50 2 56956 5 LsGetNbrsRxDigits [2] 56956 5 [Main Greeting] Number Input 2 56956 5 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 57256 5 tapie monitordigits 49 2 57256 5 LsGetNbrsRxDigits [1] 57256 5 [Main Greeting] Number Input 21 57256 5 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 57546 5 tapie monitordigits 49 2 57556 5 LsGetNbrsRxDigits [1] 57556 5 [Main Greeting] Number Input 211 57556 5 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 63515 5 Timer fired EV_TIMEOUT_ENTERDATA 63515 5 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA 63515 5 TimeoutClear 63525 5 TimeoutClear 63565 5 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 63966 5 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 63966 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 63976 5 TimeoutSet 15 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 63976 5 [Amy] Blind Transfer to 211 (Generate) 63996 5 tapic lineGenerateDigits(65711,!) => 0 64657 5 tapie generate LINEGENERATETERM_DONE 64657 5 TimeoutSet 1 EV_TAPI_GENERATE 65598 5 Timer fired EV_TAPI_GENERATE 65598 5 LsXferStart EV_TAPI_GENERATE 65598 5 TimeoutSet 1 EV_HOOKFLASHFINISHED 66599 5 Timer fired EV_HOOKFLASHFINISHED 66599 5 LsXferPlayVts EV_HOOKFLASHFINISHED 66609 5 tapic lineGenerateDigits(65711,211) => 0 67030 5 tapie generate LINEGENERATETERM_DONE 67030 5 TimeoutSet 1 EV_TAPI_GENERATE 68012 5 Timer fired EV_TAPI_GENERATE 68012 5 LsXferPlayVts EV_TAPI_GENERATE 68012 5 TimeoutSet 1 EV_TIMEOUT_HANGUP 69013 5 Timer fired EV_TIMEOUT_HANGUP 69013 5 LsXferPlayVts EV_TIMEOUT_HANGUP 69033 5 PlaySoundStop ok 69033 5 Hanging up call... 69033 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 69033 5 PlaySoundStop ok 69043 5 fnHangupCall end 69073 5 tapie linedevstate 2048 0 0 69073 5 tapie callstate IDLE 65711 0 0 69073 5 WorkingMode@Idle= 69073 5 TimeoutClear 69153 5 After Hangup script:[F:\VoiceGuide\Scripts\Voicemail Server\Voicemail Server.vgs] 69163 5 Loaded VbsAtHangup into:2 69163 5 tapi Reply 65783 0 69173 5 TimeoutClear 69173 5 [Welcome] Number Input 69173 5 Hanging up call... 69173 5 Initialise telephony (due to IDLE) 69183 5 tapic lineDeallocateCall(MainCall:65711) 0 69263 5 Waiting for a call... 69263 5 hLine=66482 69263 5 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT 74180 5 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT 95531 6 tapie linedevstate 2048 0 0 95541 6 tapie callstate OFFERING 65733 0 4 95541 6 Answer the call 95551 6 lineAnswer(65733) => 66003 95551 6 tapie callinfo CALLEDID 95551 6 tapie callinfo ORIGIN 95551 6 tapie ring 0 96082 6 tapie callstate CONNECTED 65733,1,0 96082 6 WorkingModeTAPI= 96082 6 WorkingModeScript= 96102 6 tapi Reply 66003 0 96102 6 tapie callinfo MONITORMODES 96112 6 TimeoutClear 96112 6 [Main Greeting] Number Input 96112 6 [Main Greeting] Playing (vmailrec.wav) 96242 6 PlaySoundStart ok [F:\VoiceGuide\Scripts\vmailrec.wav] 96242 6 TimeoutClear 96242 6 wa(25087,39611200) 96252 6 tapie callinfo MONITORMODES 96252 6 tapie callinfo MONITORMODES Share this post Link to post
SupportTeam Report post Posted 03/09/2003 03:45 AM I think the problem may be that you have defined the "Script To Run When Call Is Finished" on your system. We can see in the trace: 69153 5 After Hangup script:[F:\VoiceGuide\Scripts\Voicemail Server\Voicemail Server.vgs] Please try setting this to nothing, and then VoiceGuide will hang up properly instead of continuing on to the Voicemail Server.vgs script. Share this post Link to post
telecom5 Report post Posted 03/10/2003 11:32 PM Sorry, I actually just want it to go to the voicemail box for the extention that itcame back from. If a call was transfered to ext. 211, but the party doesn't answer the call I want it transfered into the voicemailbox, but insted, it is going back into my main greeting. I tried to use the fail and the timeout option, but that didn't seem to help. Does that make sense? Sorry again if I am confusing the issue. Share this post Link to post
SupportTeam Report post Posted 03/11/2003 01:18 AM Using a Fail path should do the trick... Please post your script here (as a file attachment) and I will have a look at it and advise how you can modify it to do what you need. Share this post Link to post
telecom5 Report post Posted 03/12/2003 05:26 PM Sorry, I cannot get an attachment added to this post, so I am putting the entire call log in again. I set the Fail path and also changed the After hangup Script, but it didn't help. 34579 5 tapie linedevstate 2048 0 0 34579 5 tapie callstate OFFERING 66292 0 4 34589 5 Answer the call 34589 5 lineAnswer(66292) => 65945 34589 5 tapie callinfo CALLEDID 34589 5 tapie callinfo ORIGIN 34589 5 tapie ring 0 35120 5 tapie callstate CONNECTED 66292,1,0 35120 5 WorkingModeTAPI= 35120 5 WorkingModeScript= 35150 5 tapi Reply 65945 0 35150 5 TimeoutClear 35150 5 [Main Greeting] Number Input 35150 5 [Main Greeting] Playing (vmailrec.wav) 35250 5 PlaySoundStart ok [F:\VoiceGuide\Scripts\vmailrec.wav] 35250 5 TimeoutClear 35250 5 wa(25087,23515000) 35250 5 tapie callinfo MONITORMODES 35250 5 tapie callinfo MONITORMODES 35260 5 tapie callinfo MONITORMODES 39135 5 tapie monitordigits 50 2 39135 5 LsGetNbrsPlayWelcMsg [2] 39185 5 PlaySoundStop ok 39185 5 [Main Greeting] Number Input 2 39185 5 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 39396 5 tapie monitordigits 49 2 39396 5 LsGetNbrsRxDigits [1] 39406 5 [Main Greeting] Number Input 21 39406 5 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 39696 5 tapie monitordigits 49 2 39696 5 LsGetNbrsRxDigits [1] 39696 5 [Main Greeting] Number Input 211 39696 5 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 45725 5 Timer fired EV_TIMEOUT_ENTERDATA 45725 5 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA 45725 5 TimeoutClear 45725 5 TimeoutClear 45725 5 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 46125 5 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 46125 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 46125 5 TimeoutSet 15 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 46125 5 [Amy] Blind Transfer to 211 (Generate) 46135 5 tapic lineGenerateDigits(66292,!) => 0 46796 5 tapie generate LINEGENERATETERM_DONE 46806 5 TimeoutSet 1 EV_TAPI_GENERATE 47738 5 Timer fired EV_TAPI_GENERATE 47738 5 LsXferStart EV_TAPI_GENERATE 47738 5 TimeoutSet 1 EV_HOOKFLASHFINISHED 48739 5 Timer fired EV_HOOKFLASHFINISHED 48739 5 LsXferPlayVts EV_HOOKFLASHFINISHED 48749 5 tapic lineGenerateDigits(66292,211) => 0 49170 5 tapie generate LINEGENERATETERM_DONE 49170 5 TimeoutSet 1 EV_TAPI_GENERATE 50151 5 Timer fired EV_TAPI_GENERATE 50151 5 LsXferPlayVts EV_TAPI_GENERATE 50151 5 TimeoutSet 1 EV_TIMEOUT_HANGUP 51153 5 Timer fired EV_TIMEOUT_HANGUP 51153 5 LsXferPlayVts EV_TIMEOUT_HANGUP 51153 5 PlaySoundStop ok 51153 5 Hanging up call... 51153 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 51153 5 PlaySoundStop ok 51153 5 fnHangupCall end 51193 5 tapie linedevstate 2048 0 0 51193 5 tapie callstate IDLE 66292 0 0 51193 5 WorkingMode@Idle= 51193 5 TimeoutClear 51193 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 51193 5 tapi Reply 66416 0 52154 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE 52154 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 52154 5 Initialise telephony (due to IDLE) 52154 5 tapic lineDeallocateCall(MainCall:66292) 0 52234 5 Waiting for a call... 52234 5 hLine=65856 52234 5 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT 57241 5 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT 77280 8 tapie linedevstate 2048 0 0 77781 8 tapie callstate OFFERING 65616 0 4 77781 8 Answer the call 77791 8 lineAnswer(65616) => 65833 77791 8 tapie callinfo CALLEDID 77791 8 tapie callinfo ORIGIN 77801 8 tapie ring 0 78322 8 tapie callstate CONNECTED 65616,1,0 78322 8 WorkingModeTAPI= 78332 8 WorkingModeScript= 78352 8 tapi Reply 65833 0 78362 8 tapie callinfo MONITORMODES 78362 8 TimeoutClear 78362 8 [Main Greeting] Number Input 78372 8 [Main Greeting] Playing (vmailrec.wav) 78412 8 PlaySoundStart ok [F:\VoiceGuide\Scripts\vmailrec.wav] 78412 8 TimeoutClear 78422 8 wa(25087,27837200) 78422 8 tapie callinfo MONITORMODES 78422 8 tapie callinfo MONITORMODES 78432 8 tapie monitordigits 35 2 78432 8 LsGetNbrsPlayWelcMsg [#] 78432 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 78492 8 PlaySoundStop ok 78492 8 TimeoutClear 78492 8 [Main Greeting] Number Input 78502 8 [Main Greeting] Playing (vmailrec.wav) 78532 8 PlaySoundStart ok [F:\VoiceGuide\Scripts\vmailrec.wav] 78532 8 TimeoutClear 78542 8 wa(25087,27850200) 78542 8 tapie callinfo MONITORMODES 78542 8 tapie callinfo MONITORMODES 78732 8 tapie monitordigits 50 2 78742 8 LsGetNbrsPlayWelcMsg [2] 78792 8 PlaySoundStop ok 78792 8 [Main Greeting] Number Input 2 78802 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 78993 8 tapie monitordigits 49 2 79003 8 LsGetNbrsRxDigits [1] 79003 8 [Main Greeting] Number Input 21 79003 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 79293 8 tapie monitordigits 49 2 79303 8 LsGetNbrsRxDigits [1] 79303 8 [Main Greeting] Number Input 211 79303 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 85662 8 Timer fired EV_TIMEOUT_ENTERDATA 85672 8 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA 85672 8 TimeoutClear 85672 8 TimeoutClear 85682 8 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 86083 8 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 86083 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 86083 8 TimeoutSet 15 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 86093 8 [Amy] Blind Transfer to 211 (Generate) 86103 8 tapic lineGenerateDigits(65616,!) => 0 86764 8 tapie generate LINEGENERATETERM_DONE 86764 8 TimeoutSet 1 EV_TAPI_GENERATE 87104 8 tapie monitordigits 66 2 87114 8 LsXferStart 87405 8 tapie monitordigits 65 2 87415 8 LsXferStart [A] 87705 8 Timer fired EV_TAPI_GENERATE 87705 8 LsXferStart EV_TAPI_GENERATE 87715 8 TimeoutSet 1 EV_HOOKFLASHFINISHED 88817 8 Timer fired EV_HOOKFLASHFINISHED 88827 8 LsXferPlayVts EV_HOOKFLASHFINISHED 88827 8 tapic lineGenerateDigits(65616,211) => 0 89257 8 tapie generate LINEGENERATETERM_DONE 89257 8 TimeoutSet 1 EV_TAPI_GENERATE 89618 8 tapie monitordigits 53 2 89618 8 LsXferPlayVts [5] 90249 8 Timer fired EV_TAPI_GENERATE 90249 8 LsXferPlayVts EV_TAPI_GENERATE 90249 8 TimeoutSet 1 EV_TIMEOUT_HANGUP 91260 8 Timer fired EV_TIMEOUT_HANGUP 91260 8 LsXferPlayVts EV_TIMEOUT_HANGUP 91270 8 PlaySoundStop ok 91270 8 Hanging up call... 91270 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 91280 8 PlaySoundStop ok 91280 8 fnHangupCall end 91320 8 tapie linedevstate 2048 0 0 91320 8 tapie callstate IDLE 65616 0 0 91330 8 WorkingMode@Idle= 91330 8 TimeoutClear 91340 8 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 91340 8 tapi Reply 66265 0 92292 8 Timer fired EV_TIMEOUT_TIMETOREINITLINE 92292 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 92302 8 Initialise telephony (due to IDLE) 92302 8 tapic lineDeallocateCall(MainCall:65616) 0 92372 8 Waiting for a call... 92382 8 hLine=65819 92382 8 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT 97389 8 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT Share this post Link to post
SupportTeam Report post Posted 03/12/2003 09:49 PM From the trace I see that you are using the Blind Transfer - the Blind transfer just transfers the call and does not monitor if the destination extension is busy or not… You should use Announced Transfer - this way if the transfered call is not answered then the Fail path will be taken - and you can point that to the voicemail box. TestOfAttachment.txt Share this post Link to post
SupportTeam Report post Posted 03/12/2003 09:52 PM Also, what problems have you had with attaching the script/trace? I've just tried it in the previous post and it worked OK. Share this post Link to post
telecom5 Report post Posted 03/13/2003 12:06 AM Maybe it is one of those ID 10 T errors that I tend to have.....I just couldn't get the attachment to come over. I changed the transfer and it worked....Thanks for all the help! Share this post Link to post
