Guest dmoose Report post Posted 02/10/2004 07:35 PM I am evaluating enterprise edition. my application requires that the incoming 800 number determine which group of mail boxws a call is sent to. Will I be able to determin both the incoming 800 number the caller id info and also have created a group of mailboxes that the incoming call is sent to by 800 number. Each seperate 800 number requires its own group of outgoing messages. Share this post Link to post
SupportTeam Report post Posted 02/11/2004 02:05 AM When using analog lines you will require the information relating to what number the caller dialed to be sent as Inband Signaling. You will need to enquire with the telephone company which is providing these lines to see if they can forward you this information. (If the lines are from a local PBX then you should find out if the PBX can send this info) Caller ID just tell you who is calling, not what number they have dialed. Share this post Link to post
