Dial By Name Doesnt Work
Gentlemen,,
i have on my main menu dial 6 for dial by name
when dial 6 it plays the message to dial the first 4 charactors of the persons name
when you dial the 4 digits it sits for a monent then says or press 0 for the operator
and it never matches a users name. I am attaching log files, what i did was shut down ivr
deleted all the logs then started backup the IVR then made a test call into the system and
did the dial 6 for dial by name and let it go through and fail like it does then i hung up, then stopped ivr
and zipped up the log files the log files for that test 0630 I also have included macs.vgs
which is my script for the entire system so that you could look at how i have this setup.
thanks,,
chris chandler
chris@midamcat.com
log.zip
Traces show that 9 voicemail boxes were matched when "2474" was typed to spell the name:
10000,10073,10208,10210,10378,10582,10623,10787,10826
To speak the name associated with the voicemail boxes the '_name' sound file for that voicemail box must be recorded as well.
Looks like none of these mialboxes have a '_name' sound fiel recorded for them, so none were played back.
Have a look at this section of the VBScript which you are using:
    for i = 0 to iUboundIdx
      sVmbNameFname = sPathDataVm & "VmWelc\" & aVmbIdList(i) & "_name.wav"
      if fso.FileExists(sVmbNameFname) then
          sWavs = sWavs & "press.wav," & i+1 & ".wav,aa_connectto.wav," & sVmbNameFname & ","
      end if
    next
vgEngine extract:
120545.845   7   3   1 state [SpellName] Number Input 2474
120545.845   7   3   1       path {2474} not found
120545.866   4   3   1 state [FindVmByName] RunScript, wait=2
120545.875   9         rem   remoting link constructor activated: vgServices_CommandLink
120545.892   9   3   1 rem   sVmbIdList=[10000,10073,10208,10210,10378,10582,10623,10787,10826] sVmbExtList=[10000,10073,10208,10210,10378,10582,10623,10787,10826]
120545.901   7   3   1       PrepareAndPlayWavAndTts start iModuleIdx=9, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs=
120545.901   7   3   1       rv    replace start [$RV[VmbNameWav_All]]
120545.901   7   3   1       rv    replace end   [aa_press0operator.wav]
120545.901   7   3   1       PrepareAndPlayWavAndTTS sPlayFile=aa_press0operator.wav
120545.901   7   3   1 state [SayVmbNameList] Playing wav (aa_press0operator.wav)
