dbuchanan25 Report post Posted 07/15/2014 03:29 PM Line status monitor reported a outgoing call length of 1120 seconds before I manually hung up the call on a script that had proper timeouts, etc. The script is for a satisfaction survey. This has happened recurrently, not on all calls, but on some. 0715_CallEvents doesn't report the call. File is attached. Please refer to the attached 20140715.txt first. Any ideas? CDR_20140715_out.txt 0715_CallEvents.txt 0715_ktTel.txt 2014GAQuestionaire.vgs 20140715.txt Share this post Link to post
SupportTeam Report post Posted 07/15/2014 09:58 PM Can you please post the vgEngine trace as well. Share this post Link to post
dbuchanan25 Report post Posted 07/16/2014 01:47 PM Here is the engine trace. 0715_0959_vgEngine.txt Share this post Link to post
SupportTeam Report post Posted 07/16/2014 01:59 PM Trace shows: 103859.515 7 3 2 dial StartOutgoingCall start tel[7048437652] live[c:\Program Files (x86)\VoiceGuide\Scripts\Dale Test\2014GAQuestionaire.vgs] am[retry] fax[] onNotAnswered[] onRetriesEnd[] rv[[PTID]{218101}] CampaignName[] options[] ID=8675 103859.516 7 3 2 state Dialing (auto) 7048437652 104008.276 7 3 2 state Dialing (auto) 7048437652 . connected, doing answer detection... (DX_PAMDOPTEN) 104008.279 7 3 2 state Human answer. Start [c:\Program Files (x86)\VoiceGuide\Scripts\Dale Test\2014GAQuestionaire.vgs] 104008.281 7 3 2 FindFullPathToScript_VgsOrVgp start [c:\Program Files (x86)\VoiceGuide\Scripts\Dale Test\2014GAQuestionaire.vgs] 104008.281 7 3 2 WARN cannot find full path to script [c:\Program Files (x86)\VoiceGuide\Scripts\Dale Test\2014GAQuestionaire.vgs] or [c:\Program Files (x86)\VoiceGuide\Scripts\Dale Test\2014GAQuestionaire.vgp] or [C:\Windows\system32\2014GAQuestionaire.vgs] or [C:\Windows\system32\2014GAQuestionaire.vgp] 104008.282 7 3 2 NewVgsVgm_SetVgsVgm could not find [c:\Program Files (x86)\VoiceGuide\Scripts\Dale Test\2014GAQuestionaire.vgs] so looks like the script that was specified to be used: c:\Program Files (x86)\VoiceGuide\Scripts\Dale Test\2014GAQuestionaire.vgs does not exist on your system. VoiceGuide does not continue with processing this call or more calls on the line in those situations to alert you of this issue. (if it did continue then you would have a situation where a series of calls are made and each call not doing anything on call answer as the script was not found on each call) Share this post Link to post
dbuchanan25 Report post Posted 07/17/2014 08:08 PM Thank-you again. It was a simple fix, of course, because I had put a space where it shouldn't have been. Should have been able to recognize it myself. Anyway, thanks again. Share this post Link to post
