zhang19min88 Report post Posted 08/12/2014 08:36 AM I write a script to test how to call somebody throug voiceguide. my script is very simple. only one "Send Phone Message " Module and a "Hangup " Module. but it can not work 。 In your websit I found this.“The calls will be made as soon as VoiceGuide has a line available to make a call on.” but, in my case ,no call made ,just hangup the call. vg.zip Share this post Link to post
SupportTeam Report post Posted 08/12/2014 10:44 AM Looks like you are using a T1 ISDN trunk, and in config.xml channels 21, 22 and 23 have been enabled for placing of outgoing calls. Traces show that outgoing calls are made by VoiceGuide, but the remote switch disconnects the outgoing call. Have you been able to perform an outgoing call using Dialogic's ISDIAG test application? Is the T1 ISDN trunk supplied by a telephone company? Have you asked the telephone company that supplies the T1 ISDN trunk as to why they are disconnecting the outgoing call attempt? The cause code supplied is "62 - Network congestion" 217 161902.900 4092 62 gc_MakeCall [68220739] call (SR60) 218 161902.900 4092 62 gc_MakeCall ok. crn=2800034 219 161902.900 4092 62 call progress detection not enabled as ca_intflg == DX_OPTDIS (2) 220 161902.900 4092 62 TelDriver_LineMakeCall returned 0, hli_Returned=0E7D0E88 221 161902.900 4092 62 TelDriver_LineMakeCall returned hli_Returned->crn_lastMakeCall=02800034 222 161902.900 4092 62 r generic ktTel_Completion|10000 Completion_MakeCall|0 41943092 (41943092|0|0|68220739||<result>ok</result><crn>41943092</crn>) 223 161902.900 4092 62 LineMakeCall TelDriver_LineMakeCall zsResult=[<result>ok</result><crn>41943092</crn>] 224 161902.911 3320 62 ev idx=151 : evttype=2145(2145), crn=2800034 225 161902.911 3320 62 ev GCEV_DIALING crn=2800034 crn_lastMakeCall=2800034 226 161902.911 3320 62 Event_CallState GCEV_DIALING iLineCallState=16, hCall=2800034|41943092 m_pktTelProxyClient=002C116C 227 161902.911 3320 62 r CallState GCEV_DIALING 228 161902.966 3320 62 ev idx=152 : evttype=2086(2086), crn=2800034 229 161902.966 3320 62 ev GCEV_DISCONNECTED crn=2800034 230 161902.966 3320 62 gc_ResultValue: event 0x826 received on ldev: 62 - Congestion on the line 231 161902.966 3320 62 gc_ResultValue: GC_ISDN_LIB 0x826 received on ldev: 62 - Network congestion Share this post Link to post
SupportTeam Report post Posted 08/12/2014 10:55 AM Also, it looks like you are using an older version of VoiceGuide. You can update to latest version by just stopping the VoiceGuide service and exiting all VoiceGuide applications, and then installing the latest version over the top of current installation. Share this post Link to post
zhang19min88 Report post Posted 08/14/2014 09:35 AM thanks for you replying! Share this post Link to post
