Amend A Record In A Query Query Module
Help would be much appreciated,
I have been trying to get to grips with the basics of the IVR interacting with a database, in this case Access.
I have been able to use the Help to get the IVR to query the database for information,
However, I am having a problem making changes to a record in the a table. I am able to read the table data without any problem, but for some reason I have been unable to make changes to a record in the field.
I'm using Access,
Below is the command line I'm using
UPDATE Products SET Unitsinstock=$RV[Get New Stock] WHERE ProductID=$RV[Get Product Code]
[Get New Stock] is a created in a module prior to the database query module above.
Below is the log
Where am I going wrong.....I'm sure it it is something realy obvious!
Regards
Vatsal
21906 0 tapie callstate OFFERING 65778 0 4
21906 0 tapie ring 1
24901 0 tapie ring 2
24901 0 Answer the call
24901 0 lineAnswer(65778) => 66307
24911 0 tapie callstate ACCEPTED 65778 0 0
26213 0 tapi Reply 66307 0
26223 0 tapie callstate CONNECTED 65778,0,0
26223 0 WorkingModeTAPI=
26223 0 WorkingModeScript=
26223 0 TimeoutClear
26223 0 [select Query] Playing
26223 0 [select Query] Playing (C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\Welcome to smsassist.wav)
26273 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\Welcome to smsassist.wav]
26273 0 TimeoutClear
26273 0 RunModule PLAY end
26273 0 wa(6316,82622300)
32602 0 Play End line[0] (id=826223)
32602 0 LsPlayMsg EV_PLAY_FINISHED
32602 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
32612 0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
32612 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
32622 0 TimeoutClear
32622 0 [Get Product Code] Number Input
32632 0 [Get Product Code] Playing (C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\T&C.wav)
32682 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\T&C.wav]
32682 0 TimeoutClear
32682 0 wa(11756,83263200)
35005 0 tapie monitordigits 51 2
35005 0 LsGetNbrsPlayWelcMsg [3]
35596 0 PlaySoundStop ok
35606 0 [Get Product Code] Number Input 3
35606 0 LsGetNbrsRxDigits [#]
35606 0 TimeoutClear
35616 0 fn PlaySoundStartNumbers C:\Program Files\ivg\system\voice\GetNbrsConfirmIntro.wav, C:\Program Files\ivg\system\voice\GetNbrsConfirmMenu.wav, 3, Digits
35626 0 twcal PlaySayNumber C:\Program Files\ivg\system\voice\GetNbrsConfirmIntro.wav, C:\Program Files\ivg\system\voice\GetNbrsConfirmMenu.wav, 3, , 1
35676 0 PlaySoundStartNumbers ok
35676 0 TimeoutClear
35676 0 wa(8791,83562602)
44489 0 Play End line[0] (id=835626)
44489 0 LsGetNbrsPlayConfirm EV_PLAY_FINISHED
44499 0 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
44879 0 tapie monitordigits 49 2
44879 0 LsGetNbrsPlayConfirm [1]
44879 0 PlaySoundStop ok
44889 0 TimeoutClear
44889 0 [Access Query] DB Query
44899 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
44910 0 RVreplace start: [sELECT UnitsinStock, UnitPrice FROM Goods WHERE ProductID=$RV[Get Product Code]]
44910 0 RVreplace end: [sELECT UnitsinStock, UnitPrice FROM Goods WHERE ProductID=3]
44910 0 About to execute Retrieve Operation [sELECT UnitsinStock, UnitPrice FROM Goods WHERE ProductID=3]
44920 0 [Access Query] row count=1
44930 0 TimeoutClear
44930 0 RVreplace start: [$RV[Access Query_1_1]]
44940 0 RVreplace end: [145]
44940 0 [say Stock Count Access] Say numbers: 145 as Digits
44950 0 fn PlaySoundStartNumbers , , 145, Digits
44950 0 twcal PlaySayNumber , , 145, , 1
44990 0 PlaySoundStartNumbers ok
45000 0 TimeoutClear
45000 0 wa(1973,84495002)
46982 0 Play End line[0] (id=844950)
46992 0 LsSayNbrPlay EV_PLAY_FINISHED
46992 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
46992 0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
47003 0 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
47003 0 TimeoutClear
47013 0 RVreplace start: [$RV[Access Query_2_1]]
47013 0 RVreplace end: [45]
47023 0 [say Price Access] Say numbers: 45 as Amount Cents, Decimal Point
47023 0 fn PlaySoundStartNumbers , , 45, Amount Cents, Decimal Point
47033 0 twcal PlaySayNumber , , 4500, , 12
47073 0 PlaySoundStartNumbers ok
47083 0 TimeoutClear
47083 0 wa(3901,84703304)
50998 0 Play End line[0] (id=847033)
50998 0 LsSayNbrPlay EV_PLAY_FINISHED
50998 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
51008 0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
51008 0 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
51018 0 TimeoutClear
51018 0 [Get New Stock] Number Input
51028 0 [Get New Stock] Playing (C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\amendprice.wav)
51068 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\amendprice.wav]
51078 0 TimeoutClear
51078 0 wa(2766,85102800)
53852 0 Play End line[0] (id=851028)
53862 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
53862 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
53872 0 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
54664 0 tapie monitordigits 50 2
54664 0 LsGetNbrsRxDigits [2]
54674 0 [Get New Stock] Number Input 2
54674 0 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
55815 0 tapie monitordigits 51 2
55815 0 LsGetNbrsRxDigits [3]
55825 0 [Get New Stock] Number Input 23
55825 0 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
65749 0 Timer fired EV_TIMEOUT_GOTOMODULE
65749 0 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
65759 0 TimeoutClear
65759 0 [Play 4] Playing
65769 0 [Play 4] Playing (C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\commandfailed.wav)
65810 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\commandfailed.wav]
65820 0 TimeoutClear
65820 0 RunModule PLAY end
65820 0 wa(2396,86576900)
68233 0 Play End line[0] (id=865769)
68233 0 LsPlayMsg EV_PLAY_FINISHED
68233 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
68243 0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
68243 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
68253 0 TimeoutClear
68253 0 [select Query] Playing
68263 0 [select Query] Playing (C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\Welcome to smsassist.wav)
68313 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\Welcome to smsassist.wav]
68313 0 TimeoutClear
68313 0 RunModule PLAY end
68323 0 wa(6316,86826300)
74652 0 Play End line[0] (id=868263)
74652 0 LsPlayMsg EV_PLAY_FINISHED
74652 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
74662 0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
74662 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
74672 0 TimeoutClear
74672 0 [Get Product Code] Number Input
74682 0 [Get Product Code] Playing (C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\T&C.wav)
74732 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\04MAR2003 IVR SMS ASSIST\T&C.wav]
74732 0 TimeoutClear
74732 0 wa(11756,87468200)
82373 0 LsGetNbrsPlayWelcMsg EV_TIMEOUT_HANGUP
83054 0 PlaySoundStop ok
83064 0 Hanging up call...
83064 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
83064 0 PlaySoundStop ok
83074 0 fnHangupCall end
83245 0 tapie callstate DISCONNECTED 65778,1,0
83245 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
83255 0 PlaySoundStop ok
83255 0 Hanging up call...
83265 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
83265 0 PlaySoundStop ok
83265 0 fnHangupCall end
83275 0 tapie callstate IDLE 65778 0 0
83275 0 WorkingMode@Idle=
83285 0 TimeoutClear
83285 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
83295 0 tapi Reply 65948 0
83295 0 tapi Reply 65982 0
84196 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
84196 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
84206 0 Initialise telephony (due to IDLE)
84206 0 tapic lineDeallocateCall(MainCall:65778) 0
85027 0 Waiting for a call...
85037 0 hLine=65931
85037 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
90044 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
The trace did not show the UPDATE statement executed...
I would try running the SQL query first from an SQL Query tool - and once it works then copy the query into VoiceGuide. There are many various SQL Query tools around.
(BTW: in your database is ProductID an integer field or a string field?)
