Selective Text
I have it to where Voiceguide looks up the telephone number of the caller based on the PIN code accessed; how do i get it to do one of the following (only one of the following not both)
1. Match the phone number with the Caller-id Number
2. Only return the last 4 digits of the phone number to play back to the customer.
Thanks!
Easiest to use an Evaluate Expression module. The expression you would use in the module is something like:
'$RV_CIDNUMBER' = '$RV[RetrieveCID_1]'
to return last 4 digits of the $RV[RetrieveCID_1] you will need to use a VBSCript function.
In a Run VB Script module use:
sLast4Digits = right("$RV[RetrieveCID_1]", 4)
vg.Run_ResultReturn $RV_LINEID, "[sLast4Digits]{" & sLast4Digits & "}"
set vg = Nothing
Then the last 4 digits will be accessible using the $RV[sLast4Digits] Result Variable.
