Guest Guest_zackrspv Report post Posted 02/11/2004 11:40 PM Hello. First, off, thank you for all of your help so far, you all have done a great job keeping our script working in a good fasion. With that said, i need some more help lol We are using the expression: Evaluate ['$RV_CIDNUMBER' = ""] in the NoPhone? module Of course, what we want to do, is see if the number is blocked, and if it is, it will direct it to another part of the script. Normally, from my understanding, if the above evaultation is TRUE, ie, the CIDNumber is nonexistant, then it should default to the TRUE path. And, if FALSE, that means there is a number in the CIDNumber Variable, and it will direct it down the FALSE path. However, i have tried calling this script by blocking my own number, and it directs me down the TRUE path, like it is susposed to. However, when i call again with the BLOCK OFF, ie the number is visible, it directs me down the TRUE path again. Here is the error log: 163435.55 10 linedevstate 2048 0 0 163435.55 10 callstate OFFERING 65578 0 4 163435.55 10 Lev_CallerID [5418998788,COPPER CAULDRON] 163435.56 10 callinfo CALLEDID 163435.56 10 callinfo ORIGIN 163435.56 10 ring 0 163435.56 10 Terminating process (new call). 163435.56 10 Answer the call at 2/11/2004 4:34:35 PM 163435.58 10 lineAnswer(65578) => 66124 163436.11 10 callstate CONNECTED 65578,1,0 163436.11 10 WorkingModeTAPI@Connected= 163436.13 10 WorkingModeScript@Connected= 163436.13 10 Inband detection not enabled 163436.13 10 StartLoadedVgs at 2/11/2004 4:34:36 PM 163436.13 10 tapi Reply (LineEvReply) ok 66124 0 163436.13 10 [Main 2] Number Input 163436.13 10 [Main 2] Playing (C:\Documents and Settings\Administrator\My Documents\vgs files\new\mainnew.wav) 163436.14 10 PlaySoundStart ok [C:\Documents and Settings\Administrator\My Documents\vgs files\new\mainnew.wav] 163438.89 10 dtmf 1 (65578,49,2) 163438.89 10 LsGetNbrsPlayWelcMsg 1 163438.95 10 PlaySoundStop ok 163438.95 10 [Main 2] Number Input 1 163438.95 10 path {1} not found 163439.19 10 dtmf 0 (65578,48,2) 163439.19 10 LsGetNbrsRxDigits 0 163439.20 10 [Main 2] Number Input 10 163439.20 10 [DoctorMenu] Playing 163439.20 10 [DoctorMenu] Playing (C:\Documents and Settings\Administrator\My Documents\vgs files\new\doctormenu.wav) 163439.20 10 PlaySoundStart ok [C:\Documents and Settings\Administrator\My Documents\vgs files\new\doctormenu.wav] 163439.20 10 RunModule PLAY end 163440.80 10 dtmf 1 (65578,49,2) 163440.80 10 LsPlayMsg 1 163440.84 10 PlaySoundStop ok 163440.84 10 [MakePin] Playing 163440.84 10 [MakePin] Playing (C:\Documents and Settings\Administrator\My Documents\vgs files\new\pininformation.wav) 163440.86 10 PlaySoundStart ok [C:\Documents and Settings\Administrator\My Documents\vgs files\new\pininformation.wav] 163440.86 10 RunModule PLAY end 163459.45 10 wb(54251500) 163459.52 10 Play End line[10] (id=542515) 163459.52 10 LsPlayMsg EV_PLAY_FINISHED 163459.52 10 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 163459.52 10 [NoPhone?] Evaluate ['$RV_CIDNUMBER' = ""] 163459.52 10 RVreplace start: ['$RV_CIDNUMBER' = ""] 163459.52 10 RVreplace end: ['5418998788' = ""] 163459.52 10 .Eval('5418998788' = "") 163459.52 10 Error: 1002 163459.52 10 Eval Expr result:['5418998788' = ""] 163459.52 10 path {'5418998788' = ""} not found 163459.52 10 [CantSeeNumber] Playing 163459.52 10 [CantSeeNumber] Playing (C:\Documents and Settings\Administrator\My Documents\vgs files\new\cantseenumber.wav) 163459.53 10 PlaySoundStart ok [C:\Documents and Settings\Administrator\My Documents\vgs files\new\cantseenumber.wav] 163459.53 10 RunModule PLAY end 163503.59 10 wb(56120300) 163503.66 10 Play End line[10] (id=561203) 163503.66 10 LsPlayMsg EV_PLAY_FINISHED 163503.66 10 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 163503.66 10 [GetCan'tSeeNumber] Number Input 163503.66 10 [GetCan'tSeeNumber] Playing (C:\Documents and Settings\Administrator\My Documents\vgs files\new\enterphonenumber.wav) 163503.67 10 PlaySoundStart ok [C:\Documents and Settings\Administrator\My Documents\vgs files\new\enterphonenumber.wav] 163507.00 10 Play End line[10] (id=565343) 163507.00 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 163513.55 10 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA 163513.55 10 [GetCan'tSeeNumber] Number Input 163513.55 10 [GetCan'tSeeNumber] Playing (C:\Documents and Settings\Administrator\My Documents\vgs files\new\enterphonenumber.wav) 163513.56 10 PlaySoundStart ok [C:\Documents and Settings\Administrator\My Documents\vgs files\new\enterphonenumber.wav] I can upload the vgs as well, if needed. Thanks! Share this post Link to post
SupportTeam Report post Posted 02/12/2004 12:00 AM You are using single quotes around the $RV_CIDNUMBER instead of double quotes. You need to use "double quotes" when comparing strings. Here is a trace when using "double quotes" - you can see that it works now: 105805.97 8 [Evaluate 3] Evaluate ["5418998788" = ""] 105805.98 8 .Eval(Cstr("5418998788" = "")) 105805.98 8 Eval Expr result:[False] Share this post Link to post
Guest Guest_zackrspv Report post Posted 02/12/2004 12:11 AM Yall are GodS! Thanks! It worked! Share this post Link to post
Guest bernard Report post Posted 02/12/2004 12:36 AM hi, I did have same problem. I have found work-around: check: ($RV_CIDNUMBER +1 > 1) give true when CLI received and false if no CLI received. Bernard Share this post Link to post
SupportTeam Report post Posted 02/12/2004 03:26 AM I suspect that the following should also work: In Evaluate Expression module just specify: $RV_CIDNUMBER and then in the paths you could use: on {} goto [Play 1] or on {False} goto [Play 1] both of which will match if CallerID number is blank. Similarly: on {True} goto [Play 1] will be taken if CallerID was provided. and of course you could do something like this: on {5551234} goto [Play 1] to match individual CID numbers... Share this post Link to post
