kwolbert Report post Posted 08/21/2014 09:31 PM Why ? Set WshShell = 'WScript. : commented out as WSCRIPT not used by internal script interpretor : CreateObject ("'WScript. : commented out as WSCRIPT not used by internal script interpretor : Shell") Thanks Keith Share this post Link to post
SupportTeam Report post Posted 08/21/2014 10:22 PM If you would like to use WScript or CScript interpreters to run the scripts form "Run VBScript" modules then this entry needs to be set in VG.INI:[moduleRunScript]Engine=WScriptand then VoiceGuide service restarted.For what functionality are you using the WshShell object? Share this post Link to post
kwolbert Report post Posted 08/22/2014 12:54 PM I use it to run a program. Wshell.Run programName,0,false Thanks Share this post Link to post
