invoso.com Report post Posted 10/09/2014 12:51 PM Hi, In script after transfr call we are waiting in empty play module until end of call. but now happen disconnecting described in log: 131559.651 20 107 36 ev Dialogic 134,TDX_CST, crn=2b401a1, 1107,0,0,DE_TONEON,FAX,131559.651 20 107 36 q_scr + evScriptEvent 134 FAX131559.651 20 107 36 q_scr + evScriptEvent 134 TDX_CST131559.651 7 107 36 q_scr run evScriptEvent sCode=[FAX] iActionID=0, crn=2b401a1 [1107|0|0|0|0][DE_TONEON|FAX||||] 00:00:00 max:6|00:00:00.4950283131559.651 7 107 36 se FAX 134 1107|0|0 DE_TONEON|FAX| LineState=LS_XFER_9_WAITENDCALL_DialingSide131559.651 7 107 36 LsXfer_9_WaitEndCall_OutLeg : [134:FAX] 1107,0,0,DE_TONEON,FAX,131559.651 7 107 36 LsXfer_9_WaitEndCall_OutLeg pass event to InLeg. sCode=FAX131559.651 7 4 2 q_scr + evScriptEvent 134 OTHER_LEG_FAX131559.652 7 107 36 q_scr run evScriptEvent sCode=[TDX_CST] iActionID=0, crn=2b401a1 [1107|0|0|0|0][DE_TONEON|FAX||||] 00:00:00 max:6|00:00:00.4950283131559.652 7 107 36 se TDX_CST 134 1107|0|0 DE_TONEON|FAX| LineState=LS_XFER_9_WAITENDCALL_DialingSide131559.652 7 107 36 LsXfer_9_WaitEndCall_OutLeg : [134:TDX_CST] 1107,0,0,DE_TONEON,FAX,131559.652 7 107 36 LsXfer_9_WaitEndCall_OutLeg pass event to InLeg. sCode=TDX_CST How to ignore fax tone in play module? Share this post Link to post
SupportTeam Report post Posted 10/09/2014 01:01 PM Please post a fuller trace. The posted trace excerpt does not capture the actual call hangup. Please .ZIP up longer traces and post them as attachments. Share this post Link to post
invoso.com Report post Posted 10/10/2014 07:16 AM In my opinion disconnecting reason is: 131558.708 7 4 2 path {OTHER_LEG_FAX} not found How to preserve this? Share this post Link to post
SupportTeam Report post Posted 10/10/2014 07:19 AM Quoted vgEngine trace log line is just advice that a certain path is not found. It is not a disconnection trace log entry. Share this post Link to post
invoso.com Report post Posted 10/10/2014 11:12 AM How to ignore {OTHER_LEG_FAX} in play module? Share this post Link to post
SupportTeam Report post Posted 10/10/2014 02:00 PM It would be ignored by default. No need to set anything. Share this post Link to post
invoso.com Report post Posted 10/10/2014 05:33 PM But it happen. how to prevent in this case? Share this post Link to post
SupportTeam Report post Posted 10/10/2014 09:55 PM Please post a fuller trace. We can then see what happened on system and advise. Please .ZIP up longer traces and post them as attachments. Share this post Link to post
invoso.com Report post Posted 10/29/2014 02:26 PM I attached vg_engine file. several times vg terminating calls after 8-9 minutes. example call id is: ID20141029143149196 channel 6, I found probably terminating start in 20055 line 144025.584 20 98 33 ev Dialogic 134,TDX_CST, crn=2c8014c, 1098,0,0,DE_TONEON,FAX, and after it looks like vg received fax tone and not found fax path terminating call. can you explain this case? vg_engine.zip Share this post Link to post
SupportTeam Report post Posted 10/29/2014 08:20 PM Call on port 33 was disconnected at 14:40:51 as the "DISCONNECT_USER_1" tone was heard on line: 144051.190 20 98 33 ev Dialogic 134,TDX_CST, crn=2c8014c, 1096,0,0,DE_TONEON,DISCONNECT_USER_1, ... 144051.202 7 98 33 HangupCall (LineEvCallState_DISCONNECTED) crn_in=2c8014c, L1=Disconnected ... 144051.397 20 98 33 ev CallState GCEV_DROPCALL, crn=2c8014c, iEvent=0 ,1,0,32, s1:, s2:, s3:]. build_date: 2014-04-04 13:32:46.19 The "DISCONNECT_USER_1" tone definition is set in ConfigLine.xml file. If you do not wish to have this tone detected then either remove the entire DISCONNECT_USER_1 tone definition from the ConfigLine.xml file, or set that tone definition to values unlikely to be encountered. Something like this: <Tone Name="DISCONNECT_USER_1"><Notes>Disconnect Tone</Notes><ID>DISCONNECT_USER_1</ID><Freq1>1000</Freq1><Freq1Dev>10</Freq1Dev><Freq2>2000</Freq2><Freq2Dev>10</Freq2Dev><On>100</On><OnDev>0</OnDev><Off>100</Off><OffDev>0</OffDev><Count>10</Count></Tone> Also, if there is a DISCONNECT_USER_2 tone definition in the ConfigLine.xml file then you may want to look at removing/amending it as well. You are running an E1 ISDN system, so its probably not necessary to have these tones defined. Share this post Link to post
