lucasklos Report post Posted 10/09/2014 07:14 PM Hello, I have a pretty big script used for interacting with a web service. In Many places I have "Get Numbers" modules, configured as follows: "Ask caller to enter number:" [soundFile1] Minimun Length: 3 Max Length: 10 Retries: 5 Seconds between retries: 10 Message that the entered number was not correct length or failed validation: [soundFile2], [soundFile1] And in the verify entered number tab the next code: On Error Resume Next Err.Clear Set vg = CreateObject("vgServices.CommandLink") Dim result Dim crashBody If Len("$RV_ENTEREDNUMBER")<7 Then Set objFSO = CreateObject("Scripting.FileSystemObject") Set oFile = objFSO.OpenTextFile("$RV[VBSFunctionsFile]", 1) sText = oFile.ReadAll oFile.Close ExecuteGlobal sText isAvailable = TestConnection("$RV[ServerAddress]") If isAvailable = 1 Then Dim messageXML Set messageXML = CreateObject("MSXML2.DOMDocument.6.0") messageXML.LoadXML (GenerateXMLValidateUser("$RV_ENTEREDNUMBER")) xmlHttp = SendRequest("$RV[ServerAddress]", messageXML, "ValidateIVRUser") textResponse = GetResponse(xmlHttp) If textResponse = 1 Then result = "verify_passed" ElseIf textResponse = 0 Then result = "verify_failed" Else crashBody = GenerateHTMLBody("$RV_STARTTIME", 0, "Unknown","EnterUserID",$RV_LINEID,"$RV[DlgcVoice]","$RV[DlgcNetwork]", messageXML.XML, xmlHttp) SendCrash crashBody, "$RV[CrashFrom]", "$RV[CrashTo]", "$RV[EmailUser]", "$RV[EmailPassword]", "$RV[SMTPServer]", "$RV[SMTPServerPort]" result = "error" End If Else result = "unavailable" End If Else result = "verify_failed" End If If Err.Number <>0 Then crashBody = GenerateHTMLBody("$RV_STARTTIME", Err.Number, Err.Description,"EnterUserID",$RV_LINEID,"$RV[DlgcVoice]","$RV[DlgcNetwork]", messageXML.XML, xmlHttp) SendCrash crashBody, "$RV[CrashFrom]", "$RV[CrashTo]", "$RV[EmailUser]", "$RV[EmailPassword]", "$RV[SMTPServer]", "$RV[SMTPServerPort]" vg.Run_ResultReturn $RV_LINEID, "error" Else vg.Run_ResultReturn $RV_LINEID, result End If Set vg = Nothing Set objFSO = Nothing Set oFile = Nothing Set sText = Nothing Set messageXML = Nothing Set xmlHttp = Nothing Set textResponse = Nothing and the paths: on {success} goto [EnterAssetNumber]on {*} goto [bye]on {fail} goto [bye]on {error} goto [Error]on {unavailable} goto [serviceUnnavailable] The problem is that when the user enters incorrect numbers 5 times, the module goes to the {fail} path, but also afterwards plays both sound files I selected on the "Message that the entered number was not correct length or failed validation". For example, the user enter a wrong user Id 5 times, then the VG plays the sound file configured in the {fail} path module, and the VG plays the sound file asking for the user id again. Is this Ok? How can I solve this? Thanks! Share this post Link to post
SupportTeam Report post Posted 10/09/2014 08:15 PM Are you using VoiceGuide v7 on this system? Can you please post the vgEngine trace capturing the call, we can then better advise what happened on the call. When posting traces please .ZIP them up and post as attachments. Share this post Link to post
lucasklos Report post Posted 10/09/2014 09:12 PM Hello, Thanks for the reply. Please find attached the vgEngine trace. Please let me know Share this post Link to post
SupportTeam Report post Posted 10/09/2014 09:32 PM Can you please try attaching the .ZIP again? Looks like it did not attach to previous post. Share this post Link to post
lucasklos Report post Posted 10/09/2014 09:50 PM now? 1009_1802_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 10/10/2014 04:58 AM This version should fix the bug that you encountered: [old link removed] To upgrade VoiceGuide: 1. Stop VoiceGuide Service and exit all VoiceGuide programs. (eg Script Designer, Voicemail Manager, etc) and all other programs. 2. Run new version VoiceGuide install and install into same directory as existing installation. (Do NOT uninstall the previous VoiceGuide installation). 3. Start VoiceGuide service. Running a VoiceGuide install over the top of an existing install will not overwrite existing configuration or license files (Config.xml, ConfigLine.xml, VG.INI, VmBoxList.xml, userinfo.lic) and will not remove any sound files, and will not remove any log files. Please note however that the local SQLite outdial database will be re-initialized. If you are using the local outdial database and have any queued outgoing calls that you would like to keep then this database should be backed up first. Share this post Link to post
lucasklos Report post Posted 10/10/2014 11:16 PM The problem is fixed now, thanks! Share this post Link to post
