Call Recorder
Help please,
I am trying to hook up Way2Call Hi-Phone Desktop
with VoiceGuide.
When I tried Test wizard software(Way2call)
VoiceGuide detected and recorder test.
I was wondering about my setup.
Silence detection threshold:999
Tone monitoring threshold:9999
Flash length: 700mSec
Flash guard time: 690mSec
When I tried script that comes with VoiceGuide
\VoiceGuide\Scripts\Call Recorder\Call Recorder.vgs
that is what I got(no sound recorded)
Event trace log:
190709.91 6 callstate UNKNOWN 66358 0 4
190709.91 6 callinfo CALLEDID
190711.23 6 callstate DIALTONE 66358 1 0
190711.91 6 callstate DIALING 66358 0 0
190711.91 6 callinfo CALLEDID
190712.11 6 callinfo CALLEDID
190712.30 6 callinfo CALLEDID
190712.51 6 callinfo CALLEDID
190712.70 6 callinfo CALLEDID
190712.90 6 callinfo CALLEDID
190713.11 6 callinfo CALLEDID
190716.86 6 callinfo TERMINAL
190718.02 6 callinfo TERMINAL
190718.09 6 callstate CONNECTED 66358,0,0
190718.09 6 WorkingModeTAPI@Connected=
190718.09 6 WorkingModeScript@Connected=
190718.09 6 Inband detection not enabled
190718.09 6 StartLoadedVgs at 2/12/2004 7:07:18 PM
190718.09 6 [Call Alert] Running VB Script...
190718.09 6 RVreplace start (strlen>100)
190718.10 6 Run Script waiting... (shellid=1880, process=964)
190719.02 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
190719.02 6 task still running (shellid=1880, process=964)
190720.02 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
190720.02 6 task still running (shellid=1880, process=964)
190720.97 6 cl Run_ResultReturn >>yes<<
190720.97 6 [Record Coversation] Recording
190720.97 6 RVreplace start: [$RV_CIDNUMBER_$RV_CIDNAME_$RV_MM$RV_DD_$RV_HH$RV_NN$RV_SS.wav]
190720.97 6 RVreplace end: [__0212_190720.wav]
190720.98 6 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Call Recorder\__0212_190720.wav] ok
190720.98 6 RecFile[C:\Program Files\VoiceGuide\Scripts\Call Recorder\__0212_190720.wav]
190729.97 6 callstate IDLE 66358 0 0
190729.97 6 WorkingMode@Idle=
190730.93 6 LsRecRecording EV_TIMEOUT_TIMETOREINITLINE
190730.93 6 ReinitTelephony due to IDLE start
190730.93 6 tapic lineDeallocateCall(MainCall:66358) 0
190731.10 6 LsRecRecording EV_SILENCE_DETECTED
190731.10 6 Silence Detected while recording.
190731.10 6 rec length RV: Record Coversation_RecLen100ms = 101
190731.30 6 path {silence} not found
190731.30 6 Hanging up call... [{silence} path not defined]
190731.30 6 RecSoundStop ok
190731.30 6 PlaySoundStop ok
190731.30 6 Waiting for a call...
190731.30 6 fnHangupCall end
190731.70 6 lineOpen(6) => 0
190731.70 6 Waiting for a call...
190731.70 6 lineOpen(6)LineHandle=66324
190751.95 0 sys cleanup Start
190751.95 0 sys cleanup End
Trace shows that 9 seconds after starting recording the Hi-Phone told VG that the call has ended and that VG should hang up.
That is what VG did.
If the Hi-Phone sent any data to VG after VG started recording then that data should be in file C:\Program Files\VoiceGuide\Scripts\Call Recorder\__0212_190720.wav
Does that file exist?
Looks like the Hi-Phone did not even send any sound data back to VoiceGuide...
Please place the attached file in "C:\". Once this file is there then log files will be created named: C:\VoiceGuideLogMMDD.txt. Please try recording again and post that log file...
Have you tried to play sound files with the Hi-Phone?
I'd try re-installing the Hi-Phone's Wave drivers...
TapiWrapLogSelect.txt
