Voiceguide Sql Script On Sql Server 2014
Hello VoiceGuide Team,
i'm testing the new VoiceGuide Installation and i want to create a MS SQL Server Database but when i execute the sqlfile DB_create.SQL i get an error.
Can you please send me an sqlscript which runs on SQL Server 2014.
Thanks!!!
The Error on German:
Meldung 1919, Ebene 16, Status 1, Zeile 25
Die ContactNumber-Spalte in der calltrack-Tabelle weist einen Datentyp auf, der nicht für eine Schlüsselspalte in einem Index verwendet werden kann.
Please remove these lines from Db_Create.sql
CREATE INDEX IdxCtContactNumber ON calltrack (ContactNumber);
CREATE INDEX IdxCtContactName ON calltrack (ContactName);
CREATE INDEX IdxCtCampaignName ON calltrack (CampaignName);
CREATE INDEX IdxCtOutcome ON calltrack (Outcome);
then remove all tables from the database object and try running the Db_Create.sql contents again.
