Guest Seth Report post Posted 02/19/2004 04:58 PM When I define an "on timeout" routine, it seems to ignore it and wait the full 30 second default timeout before following the fail path, but only in the announced transfer module. This is the path info: on {timeout 8} goto [Voicemail Box 10] return [Office Hours Check] on {fail} goto [Voicemail Box 10] Below is a tracelog: The lines of interest are from 115134.26 to 115206.75 115112.69 5 linedevstate 2048 0 0 115112.69 5 callstate OFFERING 65657 0 4 115112.69 5 No old processes from last call (could not obtain handle) 1224, 1612 115112.69 5 Answer the call at 2/19/2004 11:51:12 AM 115112.71 5 lineAnswer(65657) => 65640 115112.71 5 callinfo CALLEDID 115112.71 5 callinfo ORIGIN 115112.71 5 ring 0 115113.25 5 callstate CONNECTED 65657,1,0 115113.26 5 WorkingModeTAPI@Connected= 115113.26 5 WorkingModeScript@Connected= 115113.34 5 Inband detection not enabled 115113.34 5 StartLoadedVgs at 2/19/2004 11:51:13 AM 115113.34 5 tapi Reply (LineEvReply) ok 65640 0 115113.40 5 [Office Hours Check] Evaluate [((($RV_DAY >= 1) and ($RV_DAY <= 4) and (($RV_HOUR >= 9) and ($RV_HOUR <= 16))) or (($RV_DAY = 5) or ($RV_DAY = 7) and (($RV_HOUR >= 9) and ($RV_HOUR <= 12)))) or $RV_LINEID = 8] 115113.40 5 RVreplace start: [((($RV_DAY >= 1) and ($RV_DAY <= 4) and (($RV_HOUR >= 9) and ($RV_HOUR <= 16))) or (($RV_DAY = 5) or ($RV_DAY = 7) and (($RV_HOUR >= 9) and ($RV_HOUR <= 12)))) or $RV_LINEID = 8] 115113.41 5 .Eval((((4 >= 1) and (4 <= 4) and ((11 >= 9) and (11 <= 16))) or ((4 = 5) or (4 = 7) and ((11 >= 9) and (11 <= 12)))) or 5 = 8) 115113.41 5 Eval Expr result:[True] 115113.41 5 [Attend] Number Input 115113.42 5 [Attend] Playing (Attend.wav) 115113.45 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Attend.wav] 115120.31 5 dtmf 1 (65657,49,2) 115120.32 5 LsGetNbrsPlayWelcMsg 1 115120.38 5 PlaySoundStop err=0 115120.38 5 [Attend] Number Input 1 115120.39 5 [WhoIs] Playing 115120.39 5 [WhoIs] Playing (Caller.wav) 115120.47 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Caller.wav] 115120.47 5 RunModule PLAY end 115122.73 5 wb(76404800) 115122.79 5 Play End line[5] (id=764048) 115122.79 5 LsPlayMsg EV_PLAY_FINISHED 115122.80 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 115122.81 5 [Caller] Recording 115122.83 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav] 115123.03 5 wb(76647200) 115123.09 5 Play End line[5] (id=766472) 115123.09 5 LsRecPlayBeep EV_PLAY_FINISHED 115123.09 5 RVreplace start: [$RV_LINEID.wav] 115123.09 5 RVreplace end: [5.wav] 115123.18 5 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] ok 115123.18 5 RecFile[C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115127.11 5 LsRecRecording EV_TIMEOUT_GOTOMODULE 115127.17 5 RecSoundStop ok 115127.19 5 [Office] Number Input 115127.19 5 [Office] Playing (Staff.wav) 115127.23 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Staff.wav] 115133.80 5 dtmf 1 (65657,49,2) 115133.80 5 LsGetNbrsPlayWelcMsg 1 115133.85 5 PlaySoundStop err=0 115133.85 5 [Office] Number Input 1 115134.26 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 115134.27 5 [Miriam] Announced Transfer to 111 (Generate) 115134.29 5 tapic lineGenerateDigits(65657,!,0) => 0 115134.99 5 generate LINEGENERATETERM_DONE 115135.99 5 LsXferStart EV_TAPI_GENERATE 115137.00 5 LsXferPlayVts EV_HOOKFLASHFINISHED 115137.05 5 tapic lineGenerateDigits(65657,111,0) => 0 115137.50 5 generate LINEGENERATETERM_DONE 115138.45 5 LsXferPlayVts EV_TAPI_GENERATE 115138.45 5 RVreplace start: [Announce.wav, $RV[Caller]] 115138.45 5 RVreplace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115138.46 5 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav) 115138.51 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115144.05 5 wb(78212401) 115144.11 5 Play End line[5] (id=782124) 115144.11 5 LsXferPlayAnn EV_PLAY_FINISHED 115144.11 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 115144.11 5 RVreplace start: [Announce.wav, $RV[Caller]] 115144.13 5 RVreplace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115144.13 5 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav) 115144.15 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115149.73 5 wb(78778201) 115149.78 5 Play End line[5] (id=787782) 115149.79 5 LsXferPlayAnn EV_PLAY_FINISHED 115149.79 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 115149.79 5 RVreplace start: [Announce.wav, $RV[Caller]] 115149.79 5 RVreplace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115149.80 5 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav) 115149.82 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115155.37 5 wb(79346001) 115155.44 5 Play End line[5] (id=793460) 115155.45 5 LsXferPlayAnn EV_PLAY_FINISHED 115155.45 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 115155.45 5 RVreplace start: [Announce.wav, $RV[Caller]] 115155.45 5 RVreplace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115155.46 5 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav) 115155.50 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115201.06 5 wb(79911901) 115201.12 5 Play End line[5] (id=799119) 115201.12 5 LsXferPlayAnn EV_PLAY_FINISHED 115201.12 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 115201.12 5 RVreplace start: [Announce.wav, $RV[Caller]] 115201.13 5 RVreplace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115201.13 5 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav) 115201.17 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] 115206.73 5 Play End line[5] (id=804787) 115206.73 5 LsXferPlayAnn EV_PLAY_FINISHED 115206.75 5 LsXferPlayAnn EV_PLAY_FINISHED 115206.77 5 tapic lineGenerateDigits(65657,!,0) => 0 115207.46 5 generate LINEGENERATETERM_DONE 115208.40 5 LsXferPlayAnn EV_TAPI_GENERATE 115208.40 5 PlayFinishCause=CallRejected 115208.41 5 voicemail used: Scripted 115208.41 5 stack idx=1 115208.41 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgs at idx=2 115208.41 5 Going down Fail path (iXferType=1) 115208.42 5 [VmLmStart] Running vb script:[VmLmHangup.vgs] 115219.21 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=1 115219.21 5 tapi Reply (LineEvReply) ok 65913 0 115219.23 5 [VmLmHangup_ForwardLastMsg] Running VB Script... 115219.23 5 RVreplace start (strlen>500) 115219.38 5 Run Script waiting... (shellid=1448, process=1652) 115219.47 5 vm RV[VmLmRec_RecLen100ms] not set. 115219.48 5 cl Vm_Event 5, FORWARD, 01, C:\Program Files\VoiceGuide\data\VmSave\01_0219115212_1_5__.wav, , 115219.48 5 vm frwrd vmb 01 115219.49 5 vm frwrd vmb 01 end 115219.49 5 cl Vm_Event 5, MSG_NEW, 01, , , 115219.55 0 DialListDB_AddCall '6311', 0, 0, 0, , 8, 1, , MSGLAMP, , , 2, 0, 0, ESCALATION: 115219.64 5 VBScript started [wscript "C:\Program Files\VoiceGuide\data\vbs_5_vm_msglamp_on_040219115219.vbs" //I //T:3600] 115219.64 5 vm msglamp_on ok 115219.66 5 cl Run_ResultReturn >>success<< 115219.66 5 path {success} not found 115219.66 5 Hanging up call... [Run_ResultReturn - no path match (diff vgm)] 115219.68 5 HangupCall_Common Mode=AfterHangupRun 115219.68 5 ReinitTelephony due to IDLE 115219.70 5 tapic lineDeallocateCall(MainCall:65657) 0 115219.95 5 lineOpen(5) => 0 115219.96 5 Waiting for a call... 115219.96 5 LineHandle=65794 115220.29 0 dial callque update id=20 next call time 0402191154 115220.32 0 dial callque DB update returned 115220.32 8 dial found entry: tel[6311] ann[NONE] vgs[MSGLAMP] am[NONE] 115220.35 8 Dialing: 6311 115220.35 8 MakeCall => 66511 115220.35 8 TapiCbTrigSet 66511 7002 115221.32 8 tapi Reply (LineEvReply) ok 66511 0 115221.32 8 TapiCbTrigClear 115221.33 8 linedevstate 2048 0 0 115221.33 8 callstate DIALTONE 66477 0 0 115221.33 8 callstate DIALING 66477 0 0 115221.34 8 callstate PROCEEDING 66477 0 0 115221.34 8 callinfo CALLEDID 115221.34 8 callinfo REASON 115221.40 8 Lev_CallerID [0000,] 115221.40 8 callinfo ORIGIN 115230.31 8 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE 115230.31 0 dial callque delete id=20 115230.32 8 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE] 115230.32 8 RecSoundStop ok 115230.32 8 PlaySoundStop err=0 115230.33 8 Waiting for a call... 115230.33 8 fnHangupCall end 115230.43 8 linedevstate 2048 0 0 115230.44 8 callstate IDLE 66477 0 0 115230.44 8 WorkingMode@Idle= 115230.44 8 LineState(iLineId).iVgsIdx = 0 115230.45 8 tapi Reply (LineEvReply) ok 65691 0 115231.43 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 115231.43 8 ReinitTelephony due to IDLE 115231.44 8 tapic lineDeallocateCall(MainCall:66477) 0 115231.72 8 lineOpen(8) => 0 115231.72 8 Waiting for a call... 115231.72 8 LineHandle=65674 Share this post Link to post
SupportTeam Report post Posted 02/19/2004 11:13 PM I'll pass the bug report on. In the meantime as a workaround you can set the global default announced transfers/conferences timeout VG.INI file, section: [PBX] entry: AnnouncedTransfersMaxWaitTime Share this post Link to post
SupportTeam Report post Posted 02/20/2004 08:24 AM Please update your v5.1.8 install with attached .exe This will allow you to set the timeout in the "Announced Call Transfer" using a timeout path. Please note that once timeout is reached the script will go down the "Fail" path - this should be OK in practice as the Fail and Timeout paths will usually be set to go to same destination (as is set in your script). VgMulti_5.1.8003.zip Share this post Link to post
