Guest srusse01 Report post Posted 02/20/2004 01:46 AM please can you look at this output in the event logger and advise what I have done wrong. It won't let me send an email. 120617.27 7 [send Email test] Send Email 120617.27 7 RVreplace start: [test message xxx New Recruit $RV[GetStudyId_1_1]] 120617.27 7 RVreplace end: [test message xxx New Recruit 612300] 120617.27 7 RVreplace start (strlen>100) 120617.28 7 Que email to: xxxx@mail.wch.sa.gov.au 120617.28 0 eng EmailDbQueue_Insert_Error Syntax error (missing operator) in query expression ''This is an automatic message generated when VoiceGuide has randomised a woman into the xxx Trial - 612300 Hospital Code = 1000 Patient UR = 11 Mother's DOB = 12/05/84 Multiple Birth = 1 BirthWeight (1 = <1250gms, 2 = >=1250gms) = 1 Strata = 1 DateRand = 20/02/2004 Time Rand = 12:05:57 StudyID = 612300 AllocGroup = Yellow ', '', 0, 'MAPI', 0, 0, '', '', '', 0, '', 0, 0, '', '', '', 0, 0, 3, 10)'. Any help would be greatly appreciated. Share this post Link to post
SupportTeam Report post Posted 02/20/2004 02:54 AM Which version of VG are you using? Can you please post the VG script as well. Share this post Link to post
Guest Sarah Report post Posted 02/20/2004 10:10 AM I am using the latest version....I think...5.1.7 The Script is as follows [send Email test] Type=Send Email DispSize=69 Txt=Send email message and attachments. strEmailAddrTo=cnrctrials@mail.wch.sa.gov.au strEmailSubject=test message DINO New Recruit $RV[GetStudyId_1_1] strEmailMessageText=This is an automatic message generated when VoiceGuide has randomised a woman into the DINO Trial - $RV[GetStudyId_1_1]\ \ Hospital Code = $RV[Enter Hospital Code]\ Patient UR = $RV[EnterUR]\ Mother's DOB = $RV[MDOB_DAY]/$RV[MDOB_MONTH]/$RV[MDOB_YEAR]\ Multiple Birth = $RV[MultipleBirth]\ BirthWeight (1 = <1250gms, 2 = >=1250gms) = $RV[birthWeight]\ Strata = $RV[GetStrata_1_1]\ DateRand = $RV[Date]\ Time Rand = $RV[Time]\ StudyID = $RV[GetStudyId_1_1]\ AllocGroup = $RV[GetStudyId_2_1]\ strEmailAttachmentFileName= iEmailAttachmentDeleteAfterSend=0 strEmailReturnAddress= strEmailReturnName= strEmailCC= strEmailBCC= lEmailSendRetries=3 lEmailRetriesDelay=10 strEmailSendMethod_1=MAPI strEmailSmtpServ_1= lEmailSmtpPort_1=0 iEmailSmtpUseAuth_1=0 strEmailSmtpAuthUser_1= strEmailSmtpAuthPassword_1= strEmailSendMethod_2=SMTP strEmailSmtpServ_2= lEmailSmtpPort_2=0 iEmailSmtpUseAuth_2=0 strEmailSmtpAuthUser_2= strEmailSmtpAuthPassword_2= on {success} goto [Log Sent email] on {fail} goto [Log Sent email] Position=234,990 thanks for your help in anticipation Share this post Link to post
SupportTeam Report post Posted 02/21/2004 01:21 AM Just tested with the module details provided and it worked fine for me (tested with 5.1.8). Could you please try: 1. stop VG. 2. delete the EmailQue.mdb file in VoiceGuide's \data\ subdirectory 3. start VG and try running script again. (If you have recently upgraded to v5.1.7 then EmailQue.mdb may be still in the old format and that may be causing your problems) If you re still experiencing problems can you please try uninstalling v5.1.7 and installing v5.1.8 (current download from our WWW) (you may want to backup your voicemailbox config before uninstalling v5.1.7) Share this post Link to post
Guest Sarah Report post Posted 02/23/2004 12:02 AM I have now uninstalled version 5.1.7 and installed 5.1.8 as directed, and I can't even open it as I get a message "Runtime error 9 - subscript out of range and then it closes. Please help me urgently as I am running out of time to get this up and running. thanks Share this post Link to post
Guest srusse01 Report post Posted 02/23/2004 01:03 AM fixed. When I quickly entered the registration code it disappeared. Share this post Link to post
