I would like to go to another module automatically
What module is best to use for following:
After pressing key 1 play message, after message is played goto
some other module.
I would like to go to other module automatically
after message is played.
Thank you
What you need is a standard "Play Sound File" module with a path to your "other module" on "Timeout 0". This way, the script will continue to the "other module" as soon as it has played the file (your message).
== LEVENT ==
