Guest srusse01 Report post Posted 02/23/2004 12:59 AM I am trying to access an A2000 database which is running on Access 2002. I am getting the following event log, but nothing is updated to the database table. any clues? 111858.30 7 Going down On Success path. 111858.31 7 [update tblRand] DB Query 111858.31 7 Jet mode used (To use ODBC mode specify ODBC Connect string) 111858.31 7 RVreplace start: [uPDATE tblRand SET URNum='$RV[EnterUR]' and DteRand = $RV[Date] WHERE StudyID='$RV[GetStudyId_1_1]'] 111858.33 7 RVreplace end: [uPDATE tblRand SET URNum=147' and DteRand = 23/02/2004 WHERE StudyID='612300] 111858.34 7 About to execute Action Query Share this post Link to post
SupportTeam Report post Posted 02/23/2004 03:05 AM If no errors were reported then the SQL command was passed OK for execution to the database. Maybe there was a problem with the SQL statement itself? Are URNum and StudyID fields defined in the database as strings? Can you try removing the "and DteRand = 23/02/2004" from the SQL statement? Share this post Link to post
PhilRobert Report post Posted 02/23/2004 08:12 PM Try to put ' on each side of the date... like this: Update blRand set DateRand='03/03/2004' where... Hope it will help =) Share this post Link to post
Guest srusse01 Report post Posted 02/26/2004 03:03 AM I finally have this working...by separating the update into 2 modules and updating one field per module. thanks for your help Share this post Link to post
