Wave Files Stop Playing.
Katalina:
After having many problems using VoiceGuide with a voice modem I finally purchased a Dialogic D/41H. This has caused a new problem with my script:
When callers dial in they receive a welcome message. This is working normally. After the welcome message the callers are prompted to enter three digit numbers to take them to various parts of the script (i.e. 211 = injured bird, 311 = injured mammal, etc.).
When the caller enters the anything into the phone, no other wave file will play. The welcome message will not even repeat.
I have included the event trace:
82007224 4 tapi LineDevState 2048 0 0
82007240 4 tapi CallState OFFERING 0 4
82007244 4 tapi RING 0
82013253 4 tapi RING 1
82013255 4 Answer the call
82013262 4 lineAnswer(4326616) => 1
82013814 4 tapi CallState CONNECTED 0 0
82013816 4 WorkingModeTAPI@Connected=
82013824 4 WorkingModeScript@Connected=
82014052 4 tapi Reply 1 0
82014056 4 TimeoutClear
82014060 4 [111 - Main Menu] Number Input
82014394 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82014400 4 TimeoutClear
82048417 4 tapi MonitorDigits 50 2
82048420 4 LsGetNbrsPlayWelcMsg dtmf[2]
82048425 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
82048432 4 PlaySoundStop ok
82048824 4 tapi MonitorDigits 49 2
82048831 4 LsGetNbrsRxDigits dtmf[1]
82048840 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 21
82049193 4 tapi MonitorDigits 49 2
82049200 4 LsGetNbrsRxDigits dtmf[1]
82049208 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 211
82049220 4 TimeoutClear
82049229 4 TimeoutClear
82049237 4 [211 - found bird] Number Input
82049284 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82049293 4 TimeoutClear
82049301 4 Play End line[4] (id=49245)
82049310 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
82049319 4 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
82054061 4 LsGetNbrsPlayWelcMsg EV_TIMEOUT_REPLAYMSG
82054108 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82054116 4 TimeoutClear
82054143 4 Play End line[4] (id=54069)
82054151 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
82054159 4 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
82059341 4 LsGetNbrsPlayWelcMsg EV_TIMEOUT_REPLAYMSG
82059388 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82059398 4 TimeoutClear
82059407 4 Play End line[4] (id=59349)
82059416 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
82059424 4 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
82063069 4 tapi MonitorDigits 50 2
82063077 4 LsGetNbrsPlayWelcMsg dtmf[2]
82063086 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
82063096 4 PlaySoundStop ok
82063620 4 tapi MonitorDigits 49 2
82063629 4 LsGetNbrsRxDigits dtmf[1]
82063638 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 21
82064103 4 tapi MonitorDigits 49 2
82064111 4 LsGetNbrsRxDigits dtmf[1]
82064120 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 211
82064135 4 TimeoutClear
82064147 4 TimeoutClear
82064155 4 [211 - found bird] Number Input
82064203 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82064212 4 TimeoutClear
82064242 4 Play End line[4] (id=64164)
82064252 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
82064261 4 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
82068801 4 LsGetNbrsPlayWelcMsg EV_TIMEOUT_REPLAYMSG
82068849 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82068858 4 TimeoutClear
82068892 4 Play End line[4] (id=68810)
82068902 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
82068912 4 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
82072475 4 tapi MonitorDigits 49 2
82072484 4 LsGetNbrsPlayWelcMsg dtmf[1]
82072494 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
82072505 4 PlaySoundStop ok
82072709 4 tapi MonitorDigits 49 2
82072718 4 LsGetNbrsRxDigits dtmf[1]
82072729 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 11
82072972 4 tapi MonitorDigits 49 2
82072981 4 LsGetNbrsRxDigits dtmf[1]
82072991 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA 111
82073007 4 TimeoutClear
82073020 4 TimeoutClear
82073029 4 [111 - Main Menu] Number Input
82073122 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82073131 4 TimeoutClear
82073143 4 Play End line[4] (id=73040)
82073153 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
82073163 4 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
82078206 4 LsGetNbrsPlayWelcMsg EV_TIMEOUT_REPLAYMSG
82078297 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82078307 4 TimeoutClear
82078343 4 Play End line[4] (id=78216)
82078353 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
82078364 4 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
82083541 4 LsGetNbrsPlayWelcMsg EV_TIMEOUT_REPLAYMSG
82083632 4 PlaySoundStart ok [C:\Program Files\Katalina Technologies\VoiceGuide\rehab data1.wav]
82083643 4 TimeoutClear
82083655 4 Play End line[4] (id=83551)
82083665 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
82083675 4 TimeoutSet 10 EV_TIMEOUT_HANGUP
82083686 4 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
82089976 4 LsGetNbrsPlayWelcMsg EV_TIMEOUT_ENTERDATA
82089986 4 Hanging up call...
82089998 4 PlaySoundStop ok
82090011 4 TimeoutSet 2 [9100]
82090029 4 tapi Reply 2 -2147483573
82090039 4 tapi Reply 2 LINEERR_RESOURCEUNAVAIL [8000004B]
82092121 4 TimeoutClear
82092131 4 PlaySoundStop ok
82092142 4 HangupCall lineDrop start
82092193 4 HangupCall lineDrop end
82092203 4 fnHangupCall end
82092270 4 tapi LineDevState 2048 0 0
82092283 4 tapi CallState IDLE 0 0
82092295 4 WorkingMode@Idle=
82092308 4 Initialise telephony interface
82092321 4 lineDeallocateCall(IncomingCall)
82092331 4 tapi Reply 3 0
82092361 4 Waiting for a call...
82092374 4 TimeoutSet 5 [9025]
As you can see from the event trace the wave file is called, but nothing plays over the line. I have set it up to make three attempts to play the file, and then the system hangs up.
It attempts to play the wave file (211.wav in this case) 3 times in less than a minute. This wave file is about 1 minute and 5 seconds long.
Please help.
System details:
Dialogic D/41H Telephony card
Windows 98SE OS
VoiceGuide 4.5.0 Professional Edition, Single Line
Are you trying to play the same file :
rehab data1.wav
all the time, or is it a different file (and the filename just did not display properly?)
Is the sound file recorded in the Dialogic format? (PCM 11025Hz, 8bit, Mono)
Have you tried replacing the problem file with one that works (eg: one of the VoiceGuide 'system' files)?
What version of Dialogic System Release Drivers are you using? (5.01 or later should be used)
Also - Dialogic should be used on Win2000 - not 98...
