Installed Modem But Receive Line Error
When running the setup wizard I'm not sure which device to select, RAS VPN, WAN Miniport,LPT1t and so on. I do not see the Dialogic board as a Modem, and not sure if I should. When I run the test TAPI program I receive a an error -
Failed to open Line 3, reason= Lineerr_operationunavail,
I do not get a green light on the talker screen on line 3.
Were testing and would love to get this going!
The wave file installed okay, and the Tapi appeared to install okay.
