Server Ip Adress In Variable.
Is it possible to get the IP address of the server that is running VoiceGuide? We would like to hold this information in a global variable.
You may be able to obtain this by running some VBScript or .EXE/.BAT program that returns this data to VoiceGuide.
If you would like VoiceGuide to make this information available as a pre-set Result Variable that is readable to script then please contact sales@voiceguide.com with description of your requirements.
