Error Using Evaluate Expression Module
Hi, I'm trying to initialise a Result Variable right at the beginning of my script but it hangs up immediately, telling me that the True path is not defined... but it is...
Here are the paths defined in the module :
on {false} goto [Lire_Message_x]
on {true} goto [Play 33]
And here's the event log :
152049,98 0 callstate OFFERING 65945 0 4
152049,98 0 ring 1
152056,19 0 ring 2
152056,19 0 Answer the call at 27/02/2004 15:20:56
152056,19 0 lineAnswer(65945) => 65928
152056,19 0 callstate ACCEPTED 65945 0 0
152059,03 0 tapi Reply (LineEvReply) ok 65928 0
152059,03 0 callstate CONNECTED 65945,0,0
152059,03 0 WorkingModeTAPI@Connected=
152059,03 0 WorkingModeScript@Connected=
152059,03 0 Inband detection not enabled
152059,03 0 StartLoadedVgs at 27/02/2004 15:20:59
152059,03 0 [init_Cpt_Messages] Evaluate [1]
152059,03 0 .Eval(1)
152059,05 0 Eval Expr result:[1] stored in $RV[Cpt_Messages]
152059,05 0 path {1} not found
152059,05 0 Hanging up call... [No path (True) to next module defined.]
152059,05 0 RecSoundStop ok
152059,05 0 PlaySoundStop err=0
152059,05 0 fnHangupCall end
152100,70 0 callstate DISCONNECTED 65945,1,0
152100,70 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
152100,70 0 Hanging up call...
152100,70 0 RecSoundStop ok
152100,70 0 PlaySoundStop err=0
152100,70 0 fnHangupCall end
152100,70 0 callstate IDLE 65945 0 0
152100,70 0 WorkingMode@Idle=
152100,72 0 tapi Reply (LineEvReply) ok 65911 0
152100,72 0 tapi Reply (LineEvReply) ok 65894 0
152101,72 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
152101,72 0 ReinitTelephony due to IDLE
152101,72 0 tapic lineDeallocateCall(MainCall:65945) 0
152101,72 0 lineOpen(0) => 0
152101,72 0 Waiting for a call...
152101,73 0 LineHandle=65877
I really appreciate your help since it is quite important for my application to be able to set this variable to a specific number...
Thanks to all who will take time to help me = )
I tried replicating your error but it all works as expected for us here, the true/success path is taken.
Can you post the script that you are using?
Which version of VG are you using?
Here is tha trace from our script - the success path from [Evaluate 2] leads to [Play 1]. Script attached below as well.
095034.14 9 [Evaluate 2] Evaluate [1]
095034.14 9 .Eval(1)
095034.16 9 Eval Expr result:[1] stored in $RV[Cpt_Messages]
095034.16 9 path {1} not found
095034.17 9 [Play 1] Playing
095034.17 9 [Play 1] Playing (1.wav)
eval5.vgs
