Guest Lance R Report post Posted 03/02/2004 02:02 AM I created two time switch modules in my script. One for M-F 10am to 4pm. If true, go to open. If false, go to next time switch module to check if its M or F from 4pm to 5:30pm. If true go to open. If not, go to closed. The script application is saving the day of week settings properly, but is not saving the time. I can load script, set, save, close script, re-open and the times are reset (or maybe never were changed) back to midnight defaults. Suggestions? I now need to go back and reset the script back to evaluations again. 175149.48 4 [Monday, March 01, 2004 17:51] falls within [00:00-23:59 on MoTuWeThFr] Share this post Link to post
SupportTeam Report post Posted 03/02/2004 05:33 AM Looks like the Script Editor was not saving the dates/times in a way that was readable on all computers. The attached Script Editor should now save the dates/times in the format that is correctly interpreted. Please update your v5.2 installation with attached .exe and try using the Time Switch module again. VgGsd_5.2.1001.zip Share this post Link to post
