Voiceguide 5.2.1
I bought VoiceGuide 5.1.8 3 weeks ago.
Can I use VoiceGuide 5.2.1?
Is there a way to stop poping those log files in my scripts directory?
Thank you.
Your registration code will work with v5.2.1 (all 5.x registration codes will work with v5.2.1)
You must be referring to the script's log files which are saved in 3 various formats? You cannot turn these log files off. If the script was ran then an entry will be appended to the script's log file.
