Guest nightraider Report post Posted 03/10/2003 09:53 AM Hi I have successfully installed everything needed to operate VoiceGuide but still no luck - my modem does not accept the calls. Platform: - Win2k - 56k Riser Modem (Rockwell) I've checked, and the Wave Drivers are installed. The event klog file dump is: 41302 0 tapie callstate OFFERING 66494 0 4 41302 0 tapie ring 1 44056 0 tapie ring 2 44056 0 Answer the call 44056 0 lineAnswer(66494) => 66477 44066 0 tapie callstate ACCEPTED 66494 0 0 44136 0 tapi Reply 66477 LINEERR_OPERATIONFAILED [80000048] 44136 0 tapie callstate DISCONNECTED 66494,2048,0 44136 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 44136 0 PlaySoundStop ok 44136 0 Hanging up call... 44136 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 44146 0 PlaySoundStop ok 44146 0 Waiting for a call... 44146 0 fnHangupCall end 44146 0 tapie callstate IDLE 66494 0 0 44146 0 WorkingMode@Idle= 44146 0 TimeoutClear 44146 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 44156 0 tapi Reply 66460 0 45128 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE 45128 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 45128 0 Initialise telephony (due to IDLE) 45138 0 tapic lineDeallocateCall(MainCall:66494) 0 45228 0 Waiting for a call... 45238 0 hLine=66443 45238 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT 48052 0 tapie callstate OFFERING 66204 0 4 48052 0 tapie ring 1 50245 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT 52058 0 tapie ring 2 52058 0 Answer the call 52058 0 lineAnswer(66204) => 66256 52068 0 tapie callstate ACCEPTED 66204 0 0 52138 0 tapi Reply 66256 LINEERR_OPERATIONFAILED [80000048] 52138 0 tapie callstate DISCONNECTED 66204,2048,0 52138 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 52148 0 PlaySoundStop ok 52148 0 Hanging up call... 52148 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 52148 0 PlaySoundStop ok 52148 0 Waiting for a call... 52158 0 fnHangupCall end 52158 0 tapie callstate IDLE 66204 0 0 52158 0 WorkingMode@Idle= 52158 0 TimeoutClear 52168 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 52168 0 tapi Reply 66135 0 53069 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE 53069 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 53069 0 Initialise telephony (due to IDLE) 53079 0 tapic lineDeallocateCall(MainCall:66204) 0 53159 0 Waiting for a call... 53159 0 hLine=66152 53159 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT 58177 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT 07367 0 tapie linedevstate 512 0 0 35868 0 tapie linedevstate 1024 0 0 96055 0 tapie linedevstate 512 0 0 24406 0 tapie linedevstate 1024 0 0 62400 0 tapie linedevstate 512 0 0 I'll appreciate any help, I really need this to work. Also: Can I find anywhere a list of all events and their meaning? Thanks Share this post Link to post
Guest RobG Report post Posted 03/10/2003 06:21 PM Check out the post at: http://katalinatech.com/forums/index.php?a...act=ST&f=2&t=28 Your log shows: 44136 0 tapi Reply 66477 LINEERR_OPERATIONFAILED [80000048] which I believe to be the crux of your problem. Sorry I can't help any more than that. Just learning myself.... Share this post Link to post
SupportTeam Report post Posted 03/10/2003 10:09 PM Another post which covers this issue is: http://katalinatech.com/forums/index.php?a...act=ST&f=2&t=18 In summary: it's possible that your modem is a 'Speakerphone' modem, but not a 'Voice' modem - so it cannot answer calls in Voice mode, and that is why you get LINEERR_OPERATIONFAILED in reply to a lineAnswer. 44056 0 lineAnswer(66494) => 66477 44136 0 tapi Reply 66477 LINEERR_OPERATIONFAILED [80000048] Share this post Link to post
