Modem Won't Answer Calls
Hi
I have successfully installed everything needed to operate VoiceGuide but still no luck - my modem does not accept the calls.
Platform:
- Win2k
- 56k Riser Modem (Rockwell)
I've checked, and the Wave Drivers are installed.
The event klog file dump is:
41302 0 tapie callstate OFFERING 66494 0 4
41302 0 tapie ring 1
44056 0 tapie ring 2
44056 0 Answer the call
44056 0 lineAnswer(66494) => 66477
44066 0 tapie callstate ACCEPTED 66494 0 0
44136 0 tapi Reply 66477 LINEERR_OPERATIONFAILED [80000048]
44136 0 tapie callstate DISCONNECTED 66494,2048,0
44136 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
44136 0 PlaySoundStop ok
44136 0 Hanging up call...
44136 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
44146 0 PlaySoundStop ok
44146 0 Waiting for a call...
44146 0 fnHangupCall end
44146 0 tapie callstate IDLE 66494 0 0
44146 0 WorkingMode@Idle=
44146 0 TimeoutClear
44146 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
44156 0 tapi Reply 66460 0
45128 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
45128 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
45128 0 Initialise telephony (due to IDLE)
45138 0 tapic lineDeallocateCall(MainCall:66494) 0
45228 0 Waiting for a call...
45238 0 hLine=66443
45238 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
48052 0 tapie callstate OFFERING 66204 0 4
48052 0 tapie ring 1
50245 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
52058 0 tapie ring 2
52058 0 Answer the call
52058 0 lineAnswer(66204) => 66256
52068 0 tapie callstate ACCEPTED 66204 0 0
52138 0 tapi Reply 66256 LINEERR_OPERATIONFAILED [80000048]
52138 0 tapie callstate DISCONNECTED 66204,2048,0
52138 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
52148 0 PlaySoundStop ok
52148 0 Hanging up call...
52148 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
52148 0 Waiting for a call...
52158 0 fnHangupCall end
52158 0 tapie callstate IDLE 66204 0 0
52158 0 WorkingMode@Idle=
52158 0 TimeoutClear
52168 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
52168 0 tapi Reply 66135 0
53069 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
53069 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
53069 0 Initialise telephony (due to IDLE)
53079 0 tapic lineDeallocateCall(MainCall:66204) 0
53159 0 Waiting for a call...
53159 0 hLine=66152
53159 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
58177 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
07367 0 tapie linedevstate 512 0 0
35868 0 tapie linedevstate 1024 0 0
96055 0 tapie linedevstate 512 0 0
24406 0 tapie linedevstate 1024 0 0
62400 0 tapie linedevstate 512 0 0
I'll appreciate any help, I really need this to work.
Also: Can I find anywhere a list of all events and their meaning? Thanks
Another post which covers this issue is:
http://katalinatech.com/forums/index.php?a...act=ST&f=2&t=18
In summary: it's possible that your modem is a 'Speakerphone' modem, but not a 'Voice' modem - so it cannot answer calls in Voice mode, and that is why you get LINEERR_OPERATIONFAILED in reply to a lineAnswer.
