"Run Program" Module
i have a script that has a "Run Program" module.
while running the script, a program is run and a wav file is played at the same time when it comes to that module.
however, it does not go on to the next module although the program is run successfully and the wav file has played finish.
the phone just has no sound at all.
i checked the box "wait until program completes". and then for the paths, no matter i put "success" or "fail", it just will not move on to the next module.
could u advise me?
thanks.
If you select "wait until program completes" then as per VG Help file:
If the 'wait' option is selected then VoiceGuide will pause until the program completes and afterwards VoiceGuide will look for the result file which can be optionally created by the called program. The file can be created in the script's directory, or in the directory where the program was ran from. The file can either be called VGRUNRESULT_LineNumber.TXT or SHLRESLT.TXT
If you have read the above and are still experiencing problems could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is happening in your script.
Can you also post the script which you are using?
I do not have the two text files. i'm still having problems. i attach my script below to let you have a look.
i copied the events from the "Event Trace Log" to let you have a look (my run program module for the first 3 steps is simply to send sms out thru a GSM modem and playing the voice file concurrently. it will not hang up the phone after running the first module, it will just have a sound for a long period of time.):
100204.01 0 callstate OFFERING 66305 0 4
100204.01 0 ring 1
100204.61 0 Lev_CallerID [98274125,]
100207.01 0 ring 2
100207.01 0 Answer the call at 3/5/2004 10:02:07 AM
100207.01 0 lineAnswer(66305) => 65980
100207.02 0 callstate ACCEPTED 66305 0 0
100208.60 0 tapi Reply (LineEvReply) ok 65980 0
100208.61 0 callstate CONNECTED 66305,0,0
100208.61 0 WorkingModeTAPI@Connected=
100208.61 0 WorkingModeScript@Connected=
100208.61 0 Inband detection not enabled
100208.61 0 StartLoadedVgs at 3/5/2004 10:02:08 AM
100208.62 0 [Get Client ID] Run Program
100208.62 0 running:[C:\Documents and Settings\eng00507\Desktop\SMS_0.exe] WindowMode:[NormalFocus]
100208.80 0 Run Program waiting... (shellid=1616, process=664)
100208.82 0 [Get Client ID] Playing (PayGetId.wav)
100208.97 0 PlaySoundStart ok [C:\Voiceguide\Scripts\Credit Card Payment\PayGetId.wav]
100209.90 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100209.92 0 task still running (shellid=1616, process=664)
100210.92 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100210.92 0 task still running (shellid=1616, process=664)
100211.93 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100211.93 0 task still running (shellid=1616, process=664)
100212.95 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100212.95 0 task still running (shellid=1616, process=664)
100213.96 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100213.96 0 task still running (shellid=1616, process=664)
100214.97 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100214.97 0 task still running (shellid=1616, process=664)
100215.98 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100215.98 0 task still running (shellid=1616, process=664)
100216.99 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100216.99 0 task still running (shellid=1616, process=664)
100217.52 0 Play End line[0] (id=737987)
100217.52 0 LsRunWaitTillFinished EV_PLAY_FINISHED
100218.12 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100218.12 0 task still running (shellid=1616, process=664)
100219.13 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100219.13 0 task still running (shellid=1616, process=664)
100219.36 0 dtmf 4 (66305,52,2)
100219.36 0 LsRunWaitTillFinished 4
100219.36 0 path {4} not found
100219.89 0 dtmf 5 (66305,53,2)
100219.91 0 LsRunWaitTillFinished 5
100219.91 0 path {5} not found
100220.14 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100220.14 0 task still running (shellid=1616, process=664)
100220.36 0 dtmf 6 (66305,54,2)
100220.37 0 LsRunWaitTillFinished 6
100220.37 0 path {6} not found
100220.84 0 dtmf 9 (66305,57,2)
100220.85 0 LsRunWaitTillFinished 9
100220.85 0 path {9} not found
100221.14 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100221.14 0 task still running (shellid=1616, process=664)
100221.85 0 dtmf # (66305,35,2)
100221.86 0 LsRunWaitTillFinished #
100221.86 0 path {#} not found
100222.14 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100222.14 0 task still running (shellid=1616, process=664)
100223.15 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100223.15 0 task still running (shellid=1616, process=664)
100224.15 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100224.15 0 task still running (shellid=1616, process=664)
100225.15 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100225.15 0 task still running (shellid=1616, process=664)
100226.15 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100226.15 0 task still running (shellid=1616, process=664)
100227.16 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100227.16 0 task still running (shellid=1616, process=664)
100228.16 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100228.16 0 task still running (shellid=1616, process=664)
100229.16 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100229.16 0 task still running (shellid=1616, process=664)
100230.16 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100230.16 0 task still running (shellid=1616, process=664)
100231.16 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100231.16 0 task still running (shellid=1616, process=664)
100232.16 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100232.16 0 task still running (shellid=1616, process=664)
100233.16 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100233.16 0 task still running (shellid=1616, process=664)
100234.16 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100234.16 0 task still running (shellid=1616, process=664)
100235.17 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100235.17 0 task still running (shellid=1616, process=664)
100236.17 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100236.17 0 task still running (shellid=1616, process=664)
100237.17 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100237.17 0 task still running (shellid=1616, process=664)
100238.17 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100238.17 0 task still running (shellid=1616, process=664)
100239.05 0 sys cleanup Start
100239.05 0 sys cleanup End
100239.18 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100239.18 0 task still running (shellid=1616, process=664)
100240.20 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100240.20 0 task still running (shellid=1616, process=664)
100241.20 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100241.20 0 task still running (shellid=1616, process=664)
100242.36 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100242.36 0 task still running (shellid=1616, process=664)
100243.37 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100243.37 0 task still running (shellid=1616, process=664)
100244.38 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100244.38 0 task still running (shellid=1616, process=664)
100244.42 0 btn Hangup on line 0
100244.43 0 LsRunWaitTillFinished EV_TIMEOUT_HANGUP
100244.43 0 Hanging up call...
100244.43 0 RecSoundStop ok
100244.43 0 PlaySoundStop ok
100244.45 0 fnHangupCall end
100245.53 0 callstate DISCONNECTED 66305,1,0
100245.53 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
100245.54 0 Hanging up call...
100245.54 0 RecSoundStop ok
100245.55 0 PlaySoundStop ok
100245.55 0 fnHangupCall end
100245.56 0 callstate IDLE 66305 0 0
100245.56 0 WorkingMode@Idle=
100245.61 0 tapi Reply (LineEvReply) ok 65997 0
100245.61 0 tapi Reply (LineEvReply) ok 66014 0
100246.59 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
100246.59 0 ReinitTelephony due to IDLE start
100246.59 0 tapic lineDeallocateCall(MainCall:66305) 0
100246.61 0 lineOpen(0) => 0
100246.61 0 Waiting for a call...
100246.61 0 lineOpen(0)LineHandle=66031
hope you can help me solve this problem. thanks
Credit_Card_Payment_1_.vgs
It looks like the program you start (C:\Documents and Settings\eng00507\Desktop\SMS_0.exe) never actually exits...
That's why you see all those "task still running" entries in the log file....
As said in VG Help file:
If you do no need to wait for program to complete the select "do not wait for program to complete" option.
Why are you waiting for program complete if it is not returning any info back to VG anyway?
Can you make this .exe exit after it has stopped doing what it is supposed to do?
You can have VG to shutdown the program as well. From VG Help file:
Timeout Paths
When used in Run Program module, a Timeout Path can be used to limit the maximum amount of time the module will wait for the called program to finish (when "Wait until program finishes" option is selected). When the timeout is reached the module will close the program it has called, and go the module specified in the Timeout Path.
