iTime Report post Posted 04/01/2016 08:29 PM Hi VG support, Our Script has a "Post Hang Up" script that is set to run after hangup. It is referring to old path (before 64 bit) like "C:\Program Files\VoiceGuide\Scripts...." without "(x86)", but VG seemed to be able to search through and find its correct path including " (x86)". However, there was one call that failed to run this: 224212.079 7 3 1 after hangup script as supplied: [C:\Program Files\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs] 224212.079 7 3 1 FindFullPathToScript_VgsOrVgp start [C:\Program Files\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs] 224212.079 7 3 1 WARN cannot find any of these scripts [C:\Program Files\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs] or [C:\Program Files\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgp] or [C:\Windows\system32\PostHangUp_Hiring.vgs] or [C:\Windows\system32\PostHangUp_Hiring.vgp] 224212.079 7 3 1 WARN could not find AfterHangup script 224212.079 7 3 1 HangupCall (AfterHangupScriptError_RecordDelay) crn_in=0, L1=Disconnected, L2=Running_Normal, lPlayId=0, lRecId=0 224212.079 7 3 1 HangupCall crn_connected=0, crn_NewCallArriving=0, crn_CurrentMakeCall=0, crn_InProcessOfReleasing=8000001 224212.079 7 3 1 rv add Hangup Source|AfterHangupScriptError_RecordDelay 224212.080 7 3 1 HangupCall sScriptToRunOnHangup=[C:\Program Files\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs] 224212.080 7 3 1 no script running on this line. AfterHangup script will not be ran. 224212.080 7 3 1 rv add DropCall_Source|Hangup the Call 224212.080 7 3 1 crn 0 set to crn_InProcessOfReleasing 8000001 224212.080 7 3 1 state Hanging up... [AfterHangupScriptError_RecordDelay] If you see other calls, it looks like VG was able to find the correct path and ran it successfully like the one below: 125946.387 7 7 2 after hangup script as supplied: [C:\Program Files\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs] 125946.388 7 7 2 FindFullPathToScript_VgsOrVgp start [C:\Program Files\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs] 125946.388 7 7 2 after hangup script after searching: [C:\Program Files (x86)\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs] 125946.388 7 LoadedVgs_Find C:\Program Files (x86)\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs at idx=2 125946.388 7 7 2 After Hangup script run first module 125946.388 7 7 2 L2_set Running_AfterHangup (called from StartAfterHangupScriptIfDefined) 125946.388 7 7 2 t timer clear (force=False) 125946.388 7 7 2 RunModule start 125946.388 7 7 2 RunModule start Run VB Script, [ProcessFinishUpHiring], iModuleIdx=69, previous: vgm=9, vgs=2:1 125946.388 7 7 2 t timer set 60 sec : EV_TIMEOUT_GOTOMODULE 125946.388 7 7 2 QueueUserWorkItem vbScript : modVbs 125946.389 7 7 2 HangupCall exit after starting afterhangup script 125946.389 22 7 2 task runscr Run_VBS vgm=69, file=, engine=[WScript] 125946.389 22 7 2 runscr strIni_moduleRunScript_Engine=WScript 125946.389 22 7 2 state [ProcessFinishUpHiring] RunScript vbs, onhold= I have modified the path value of "Script to run when call is finished:" to include "(x86)" now, but I would like to know why this failed only for this call and it would not happen anymore. Please see the attached files. Thank you. AfterHangUpIssue.zip Share this post Link to post
SupportTeam Report post Posted 04/02/2016 12:22 AM The specified "After Hangup" script did not exist. That's why no "After Hangup" script was ran. In cases where the specified "After Hangup" script path points to a non-existing file, VoiceGuide will look in the directory where the current script is running to see if the "After Hangup" script is there instead, but in this case no script was even running on the line so that did not happen. In general, when specifying "After Hangup" script path, it should be ensured that it points to a file that exits. Share this post Link to post
iTime Report post Posted 04/02/2016 12:31 AM Yes, I understand that VG will look for the directory where the script lies, but why failed only on that specific call? As you can see there are several more calls that detected answering machine, exact same script and same path to find the same "PostHangup_Hiring.vgs." (We only have this post hangup script for all occasions) You can tell (from above) that both failed and successful cases got to: FindFullPathToScript_VgsOrVgp start [C:\Program Files\VoiceGuide\Scripts\IntelliTime\PostHangUp_Hiring.vgs] so I do not understand your explanation: in this case no script was even running on the line so that did not happen. Would you elaborate this part? Does it mean there are differences between those 2 cases even if they have got to the same point of process? Thanks again. Share this post Link to post
SupportTeam Report post Posted 04/02/2016 12:55 AM The call ended while VoiceGuide was still waiting for the 'answering machine message' to end. The script does not start until the 'answering machine message' ends. As no script was running on system at time the call ended, VoiceGuide did not know what other directories to look in to check if the "After Hangup" script coupld perhaps be there instead. in the provided traces this was the only call that ended while the 'answering machine message' was still playing. (also: most likely in this case it was not an actual voicemail welcome message, but some sort of pre-recorded annoucement and the call was ended immediately afterwards) Share this post Link to post
iTime Report post Posted 04/05/2016 03:39 PM Thanks for the clarification. So, does this mean it would be fixed even if I corrected the path for "Run After Hangup" setting in the script? I am trying to prevent this from happening. Share this post Link to post
SupportTeam Report post Posted 04/05/2016 10:02 PM So, does this mean it would be fixed even if I corrected the path for "Run After Hangup" setting in the script? Yes. If the path to the 'After Hangup' script is set correctly - pointing to an existing script - then VoiceGuide will run that 'After Hangup' script... Share this post Link to post
