invoso.com Report post Posted 04/21/2016 07:38 AM Can You explain why client on channel 1 in module Client_Agent2_conversation after hangup (disconnecting) call by Agent 2 not forwarding like declared in paths? on {OTHER_LEG_DISCONNECTED} goto [finish_call]on {DISCONNECTED} goto [finish_call] 0421_0919_vgEngine test.zip Share this post Link to post
SupportTeam Report post Posted 04/21/2016 10:28 PM When the caller hangs up the 'Afer Hangup' script is ran. Please see: http://www.voiceguide.com/vghelp/source/html/call%20finish.htm We can see from trace that the 'After Hangup' was specified for this script. It is: _termination.vgs and the _termination.vgs was started as expected: 092651.900 7 2 1 running AfterHangupScript as recording -530326 completed 092651.901 7 2 1 after hangup script as supplied: [_termination.vgs] 092651.901 7 2 1 FindFullPathToScript_VgsOrVgp start [_termination.vgs] 092651.901 7 2 1 after hangup script after searching: [_termination.vgs] 092651.901 7 LoadedVgs_Find _termination.vgs at idx=6 092651.901 7 2 1 After Hangup script run first module 092651.901 7 2 1 L2_set Running_AfterHangup (called from StartAfterHangupScriptIfDefined) 092651.901 7 2 1 t timer clear (force=False) 092651.901 7 2 1 RunModule start 092651.901 7 2 1 RunModule start Database Query, [vg_polaczenia_update_end_first], iModuleIdx=484, previous: vgm=528, vgs=6:7 092651.901 7 2 1 state [vg_polaczenia_update_end_first] DB Query 092651.901 7 2 1 rv replace start [$RV[connection_string]] 092651.901 7 2 1 rv replace end [ODBC; Driver=PostgreSQL Unicode; Server=IP; Port=5432; Database=database;UID=user;PWD=pass] 092651.901 7 2 1 rv replace start ------------------------------ UPDATE polaczenia SET call_end=now(), stop=to_char(now(), 'HH24MISS'), hangup_source='$RV[Hangup Source]' WHERE session_id='$RV[session_id]' ------------------------------ Share this post Link to post
invoso.com Report post Posted 04/26/2016 10:08 AM Sorry, I don't understand, I have script Using : on {OTHER_LEG_DISCONNECTED} goto [prepaid_two_tariffs_back.vgs|] (7.5.5915.18699 RELEASE options75) and script has termination script too and it's working properly. In case Other leg disconnected script forwarding to next script. It looks that {OTHER_LEG_DISCONNECTED} has higher priority than termination script. Why it doesn't work in this case? Maybe again versions Problem? v7.4.5546.36085 (09-Mar-15 20:02:50.85) 101348.773 20 179 60 ev CallState GCEV_DISCONNECTED, crn=28c0183, iEvent=0 ,16384,0,64, s1:, s2:, s3:]. build_date: 09-Mar-15 20:02:50.85 101348.773 20 179 60 q_scr + evCallState 0 GCEV_DISCONNECTED 101348.773 7 179 60 q_scr run evCallState sCode=[GCEV_DISCONNECTED] iActionID=0, crn=28c0183 [16384|0|64|0|0][|||||] 00:00:00 max:4|00:00:00.4470255 101348.773 7 179 60 callstate crn_event=28c0183 0|GCEV_DISCONNECTED state=16384|Disconnected calldirection=0 gcCallState=64 [||], ScriptState=LS_XFER_7_WAITOUTCOMEOUTGOINGCALL_DIALINGSIDE 101348.773 7 179 60 LineEvCallState L1_current=Connected crn_event=28c0183,ev=0,GCEV_DISCONNECTED,0, sParam1= 101348.773 7 179 60 LineEvCallState LINECALLSTATE_DISCONNECTED begin 101348.773 7 179 60 TsReset [LineEvCallState_LINECALLSTATE_DISCONNECTED], OtherLegLid=25 101348.773 7 q_tel + cmd_TsReset 0 [0,0,0,0,0][dtiB2T30||dtiB1T9||] 101348.773 7 179 60 OtherLegLid_ClearBoth 179 25 caller:LineEvCallState_LINECALLSTATE_DISCONNECTED 101348.773 8 q_tel run cmd_TsReset 0 00:00:00 max:4|00:00:00.1450083 101348.773 7 25 9 OtherLegLid_ClearBoth 179 25 caller:LineEvCallState_LINECALLSTATE_DISCONNECTED 101348.773 7 179 60 send OTHER_LEG_DISCONNECTED to OtherLegLid=25 101348.773 7 25 9 q_scr + evScriptEvent 0 OTHER_LEG_DISCONNECTED 101348.773 7 179 60 L1_set Disconnected (iState=LS_XFER_7_WAITOUTCOMEOUTGOINGCALL_DIALINGSIDE) 101348.773 7 179 60 in LINECALLSTATE_DISCONNECTED iState=LS_XFER_7_WAITOUTCOMEOUTGOINGCALL_DIALINGSIDE 101348.773 7 179 60 HangupCall (LineEvCallState_DISCONNECTED) crn_in=28c0183, L1=Disconnected, L2=Running_Normal, lPlayId=0, lRecId=0 101348.773 7 179 60 ccrn_connected=0, crn_NewCallArriving=0, crn_CurrentMakeCall=0, crn_InProcessOfReleasing=28c0183 101348.773 7 179 60 rv add Hangup Source|LineEvCallState_DISCONNECTED 101348.773 7 179 60 HangupCall sScriptToRunOnHangup=[] 101348.773 7 179 60 no script running on this line. AfterHangup script will not be ran. 101348.774 7 179 60 rv add DropCall_Source| 101348.774 7 179 60 state Hanging up... [LineEvCallState_DISCONNECTED] 101348.774 7 179 60 logs not written as LogEntryWritten=1 101348.774 7 179 60 L2_set Idle_WaitingForNextCall (called from HangupCall) 101348.774 7 179 60 t timer set 3 sec : EV_TIMEOUT_AFTERIDLE_ALLOWOUT 101348.774 7 179 60 GoOnHoook_IssueDropCall start (crn_in=28c0183, crn_connected=0, crn_makecall=0, crn_NewCallArriving=0, crn_InProcessOfReleasing=28c0183, L1=Disconnected) 101348.774 7 179 60 t timer set 20 sec : EV_TIMEOUT_WAITFORIDLEAFTERDropCall 101348.774 7 179 60 set crn_InProcessOfReleasing=28c0183 101348.774 7 179 60 not setting crn_CurrentConnected to 0 as crn_CurrentConnected=0 and evnt crn=28c0183 101348.774 7 179 60 set crn_connected=0 (called from GoOnHoook_IssueDropCall) 101348.774 7 179 60 q_tel + cmd_DropCall 28c0183 [0,0,0,0,0][||||] 101348.774 7 179 60 GoOnHoook_IssueDropCall end 101348.774 7 25 9 q_scr run evScriptEvent sCode=[OTHER_LEG_DISCONNECTED] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00.0010001 max:4|00:00:00.4470255 101348.774 7 25 9 se OTHER_LEG_DISCONNECTED 0 0|0|0 || LineState=LS_PLAY_PLAYMSGFINISHED 101348.774 7 25 9 LsPlayMsgFinished EV_UNKNOWN_0,OTHER_LEG_DISCONNECTED, [ ], [ ], [] 101348.774 7 25 9 rv replace start ------------------------------ on {timeout $RV[warning before end]} goto [WHITEPHONE_play_warning] on {OTHER_LEG_DISCONNECTED} goto [prepaid_two_tariffs_back.vgs|] ------------------------------ 101348.774 7 25 9 rv replace end [on {timeout 123090} goto [WHITEPHONE_play_warning] on {OTHER_LEG_DISCONNECTED} goto [prepaid_two_tariffs_back.vgs|] ] 101348.774 7 25 9 path {OTHER_LEG_DISCONNECTED} found (at offset 55) 101348.774 7 25 9 FindNextVgmTitleInPathList: next module title is=[prepaid_two_tariffs_back.vgs|] 101348.774 7 25 9 script and module specified 101348.774 7 25 9 NewVgsVgm_Goto_Setup dest=prepaid_two_tariffs_back.vgs|, return=|, lSaveSourceOnCallStack=0 101348.774 7 25 9 rv add ScriptEnd_Time|2016-04-26 10:13:48 101348.774 7 25 9 rv add ScriptEnd_Goto_Script|prepaid_two_tariffs_back.vgs 101348.775 7 25 9 rv add ScriptEnd_Goto_Module| 101348.775 7 25 9 WriteToLogFiles_CurrScriptOnly begin 101348.775 7 25 9 WriteToLogFiles_DoWrite begin : strLogFnameLessSuffix=whitephone_prepaid_two_tariffs 101348.775 7 25 9 WriteToLogFiles_DoWrite : log subdirectory does not exist: log 101348.789 8 179 60 q_tel run cmd_DropCall 28c0183 00:00:00.0150009 max:4|00:00:00.1450083 101348.810 20 179 60 ev CallState GCEV_DROPCALL, crn=28c0183, iEvent=0 ,1,0,32, s1:, s2:, s3:]. build_date: 09-Mar-15 20:02:50.85 101348.810 20 179 60 q_scr + evCallState 0 GCEV_DROPCALL 101348.824 7 25 9 WriteToLogFiles_DoWrite completed 101348.824 7 25 9 rv add ScriptStart_Time|2016-04-26 10:13:48 101348.824 7 25 9 rv add ScriptStart_CalledFrom_Script|prepaid_two_tariffs.vgs 101348.826 7 25 9 rv add ScriptStart_CalledFrom_Module|just_wait_input_play 101348.826 7 25 9 FindFullPathToScript_VgsOrVgp start [prepaid_two_tariffs_back.vgs] 101348.826 7 VgsScriptLoad load start [prepaid_two_tariffs_back.vgs] iVgsLoadCounter=10 101348.826 7 VgsScriptLoad iVgsId=10 101348.826 7 VgsScriptLoad about to do ProcessVgsEntry loop 101348.847 7 25 9 loaded [prepaid_two_tariffs_back.vgs] into:10 101348.847 7 25 9 ScriptToRunOnHangup=[prepaid_temination.vgp] in NewVgsVgm_SetVgsVgm 1 101348.847 7 25 9 rvns add ScriptsPath| 101348.847 7 25 9 StartModuleDefault=[Hangup_Source_next_call] Share this post Link to post
SupportTeam Report post Posted 04/26/2016 09:47 PM It looks that {OTHER_LEG_DISCONNECTED} has higher priority than termination script. The above statement is incorrect. Handling of OTHER_LEG_DISCONNECTED event does not take precedence over starting the 'After Hangup' script. No paths specified in module take any precedence over the process that starts the 'After Hangup' script. The 'After Hangup' script will be started immediately upon call ending. The trace posted just now shows a different situation to trace posted 5 days before (in the first post of this thread). The two traces posted capture different scenarios : In the first trace VoicegGuide hangs up the call. but in the trace just posted now, the party on the 2nd leg of the call (the agent?) hangs up the call. Note that there are no OTHER_LEG_DISCONNECTED events in the trace posted at the beginning of this thread. Share this post Link to post
invoso.com Report post Posted 04/27/2016 10:28 AM I think, no difference between two scenarios as you see, but difference is in connection method. OTHER_LEG_DISCONNECTED working properly when call is transferred by transfer module, our problem is because we join two channels using VBscript and maybe because VG not recognizing OTHER_LEG Maybe I have to declare it? Share this post Link to post
SupportTeam Report post Posted 04/27/2016 10:52 PM The difference between the two posted trace excerpts is in the disconnection. In the first trace VoiceGuide ends the call. In the second trace the remote party on the 2nd leg of the transferred call (the agent?) hangs up. If VoiceGuide hangs up the call there will not be any DISCONNECTED event at VoiceGuide end of the call, as it was not the remote party/side that disconnected. And if there are no DISCONNECTED events, then there will not be any OTHER_LEG_DISCONNECTED events issued on the other call leg either. Share this post Link to post
