Postgres Query Error
Can You help to understand what is wrang when VG returned this:
205857.418  85   7   3       db    odbc  DataAdapter.Fill init.
205857.418  85   7   3       db    odbc  DataAdapter.Fill call.
205857.438  85   7   3       db    odbc  DataAdapter.Fill returned. tsFillTime=00:00:00.0190019
205857.438  85   7   3 ERROR v7.4.5546.36085 (09-Mar-15 20:02:50.85) ConnectAndRun_Odbc : DataTableReader Cannot be created. There is no DataTable in DataSet.
   at System.Data.DataSet.CreateDataReader()
   at (Object )
   at ..()
205857.438  85   7   3       db    completed.  SqlQueryType=ERROR, RowsCount=0, sRv=
205857.438  85   7   3       db    completed. iRunWait=1, WavPlayWasStarted=0, WavPlayHasNowFinished=0
205857.438  85   7   3       db    completed. strError=DataTableReader Cannot be created. There is no DataTable in DataSet.
205857.438  85   7   3       path {DataTableReader Cannot be created. There is no DataTable in DataSet.} not found
Looks like the ODBC driver used here could not process the request and returned an error.
Looking at ODBC driver's logs may give more information as to what the actual issue was.
If you can advise in more detail what type of SQL command was issued to database we can then have a closer look at this.
Was this SQL command a call to a stored procedure or some other non-commonly used statement?
