invoso.com Report post Posted 09/15/2016 07:06 AM Some transfer (outbound) call has error: no CallerId presentation 145553.389 7 46 16 state [Dialout_Transfer_Target_ann] Blind Dial and Connect to 1070003620xxxxxx 145553.389 7 46 16 dial IvrDevState strCID=[], strDialoutOptions=[<CallerId>+$RV[CLIP_ID]</CallerId>] 145553.389 7 46 16 dial sCidSentThisCall=+$RV[CLIP_ID] (extracted from strDialoutOptions) 145553.389 7 46 16 rv replace start [+$RV[CLIP_ID]] 145553.389 7 46 16 rv replace end [+361xxxxxx] 145553.390 7 46 16 dial sCidSentThisCall=[+361xxxxxx] (post RV replace) 145553.390 7 46 16 rv replace start [<CallerId>+$RV[CLIP_ID]</CallerId>] 145553.390 7 46 16 rv replace end [<CallerId>+361xxxxxx</CallerId>] 145553.390 7 46 16 dial strDialoutOptions=[<CallerId>+361xxxxxx</CallerId>] (post RV replace) 145553.390 7 46 16 outbound call announce message not defined. vgm=1166 [Dialout_Transfer_Target_ann] 145553.390 7 46 16 setting CONNECT_IMMEDIATELY as iXferType = XT_DC_BLIND It happen sometimes not each call. In this case our PBX has empty CallerId field. 0914_ktTel.zip Share this post Link to post
SupportTeam Report post Posted 09/15/2016 10:10 PM If CallerID is correctly specified, then it will be sent out. On many ISDN systems (like the one used here) CallerID sent out in the ISDN SETUP packet does not use the "+" sign. There are about 3000 outgoing calls in the uploaded trace but only 4 of those calls use the "+" sign when specifying the CallerID. The 4 calls were loaded between 2pm-3pm, and one of them matches up with the vgEngine trace example that you posted: Line 709789: 658 135926.297 5660 146 fn LineMakeCall(iLineId=146, iCallRequestId=0 (ignored), strNumberToCall=[107056502511215], callprog=CONNECT_IMMEDIATELY, timeout=60, params:0,49,cidtosend=[+227154477],opt=[<calltype>DialAndConf</calltype><CallerId>+227154477</CallerId>]) Line 784632: 443 144104.023 5660 176 fn LineMakeCall(iLineId=176, iCallRequestId=0 (ignored), strNumberToCall=[107000421903705669], callprog=CONNECT_IMMEDIATELY, timeout=60, params:0,25,cidtosend=[+421248703591],opt=[<calltype>DialAndConf</calltype><CallerId>+421248703591</CallerId>]) Line 805689: 274 145237.563 5660 161 fn LineMakeCall(iLineId=161, iCallRequestId=0 (ignored), strNumberToCall=[10700036206655048], callprog=CONNECT_IMMEDIATELY, timeout=60, params:0,82,cidtosend=[+3618829400],opt=[<calltype>DialAndConf</calltype><CallerId>+3618829400</CallerId>]) Line 813513: 017 145553.392 5660 152 fn LineMakeCall(iLineId=152, iCallRequestId=0 (ignored), strNumberToCall=[10700036202685141], callprog=CONNECT_IMMEDIATELY, timeout=60, params:0,46,cidtosend=[+3618829400],opt=[<calltype>DialAndConf</calltype><CallerId>+3618829400</CallerId>]) Please try loading the calls without using the "+" sign as part of the outgoing Caller ID setting on your system/trunks. Share this post Link to post
