invoso.com Report post Posted 10/10/2016 04:12 PM Hi, we found VG not correct recognizing DTMF tones. All dtmf tones on other_leg are not identified as OTHER_LEG and dtmf tone from other_leg vg see as initial line signal. any side dtmf tone is recognized as initial line signal. in log file connection between lines: 16 and 101 starting wait to dtmf code: 175200.749 9 16 6 state [switch_disconnect_recorded_call] Playing wav () and in lines: 175212.233 21 16 6 ev dtmf 1 (41943046,49,0) iConferenceOtherLegLid=101, iConferenceOtherLegIvrDevPort=34175212.233 21 16 6 q_scr + evScriptEvent 49 1175212.233 21 101 34 q_scr + evScriptEvent 49 OTHER_LEG_1 vg see dtmf tone as first line not other leg. Why? I used smartphones to test. 1010_1748_vgEngine - Kopia (2).zip 1010_ktTel.zip Share this post Link to post
SupportTeam Report post Posted 10/11/2016 03:26 AM Attached trace shows that call on port 6 made an outgoing call on port 34 and the two call were bridged together: 175200.621 9 16 6 state [Transfer Call fa with CALLER ID] in_leg 6 <=> 34 502131658 The connection was then recorded: 175200.646 15 16 6 rem Record_2Lines_Start [16,16,101,C:\callrecord\ID20161010_175145_41_6_70320_175200.wav] options=[] and about 12 seconds into the connected call the caller on port 6 pressed the key "1" on their keypad: 175212.233 21 16 6 ev dtmf 1 (41943046,49,0) iConferenceOtherLegLid=101, iConferenceOtherLegIvrDevPort=34 The script running on port 6 did not do anything as no path to react to DTMF 1 event was set in module [switch_disconnect_recorded_call] in which that script was at the time: 175212.233 9 16 6 state [switch_disconnect_recorded_call] Number Input 1175212.233 9 16 6 path {1} not found The event as passed to the outgoing call on port 34, but as there was no script running on port 34 that event was just ignored: 175212.233 9 101 34 q_scr run evScriptEvent sCode=[OTHER_LEG_1] iActionID=0, crn=0175212.233 9 101 34 se OTHER_LEG_1 49 0|0|0 || LineState=LS_XFER_9_WAITENDCALL_DialingSide175212.233 9 101 34 LsXfer_9_WaitEndCall_OutLeg : [49:OTHER_LEG_1] 0,0,0 ,, further "1" keypresses were made by caller on port 6, but again no matching paths were specified in module [switch_disconnect_recorded_call], so no action was taken: 175221.219 21 16 6 ev dtmf 1 (41943046,49,0) iConferenceOtherLegLid=101, iConferenceOtherLegIvrDevPort=34...175221.220 9 16 6 state [switch_disconnect_recorded_call] Number Input 11175221.221 9 16 6 path {11} not found 175226.761 21 16 6 ev dtmf 1 (41943046,49,0) iConferenceOtherLegLid=101, iConferenceOtherLegIvrDevPort=34...175226.761 9 16 6 state [switch_disconnect_recorded_call] Number Input 111175226.761 9 16 6 path {111} not found 175236.289 21 16 6 ev dtmf 1 (41943046,49,0) iConferenceOtherLegLid=101, iConferenceOtherLegIvrDevPort=34...175236.289 9 16 6 state [switch_disconnect_recorded_call] Number Input 1111175236.289 9 16 6 path {1111} not found 175244.739 21 16 6 ev dtmf 1 (41943046,49,0) iConferenceOtherLegLid=101, iConferenceOtherLegIvrDevPort=34...175244.739 9 16 6 state [switch_disconnect_recorded_call] Number Input 11111175244.739 9 16 6 path {11111} not found The above DTMF "1" keypresses were passed onto port 34 as "OTHER_LEG_1" events: 175212.233 21 101 34 q_scr + evScriptEvent 49 OTHER_LEG_1175212.233 9 101 34 se OTHER_LEG_1 49 0|0|0 || LineState=LS_XFER_9_WAITENDCALL_DialingSide and 175226.761 21 101 34 q_scr + evScriptEvent 49 OTHER_LEG_1175226.762 9 101 34 se OTHER_LEG_1 49 0|0|0 || LineState=LS_XFER_9_WAITENDCALL_DialingSide etc. But as no script was running on port 34 those "OTHER_LEG_1" events were just ignored. The outgoing call on port 34 eventually disconnected about 50 seconds after it was made (the recipeint of that outgoing call hung up) : 175248.566 21 101 34 ev CallState GCEV_DISCONNECTED, crn=280005b, iEvent=0 ,16384,0,64, s1:, s2:, s3:] and the OTHER_LEG_DISCONNECTED event was passed to port 6, but as no path to match that event was set in module [switch_disconnect_recorded_call], the call on port 6 was just hung up: 175248.567 9 101 34 send OTHER_LEG_DISCONNECTED to OtherLegLid=16175248.568 9 16 6 path {OTHER_LEG_DISCONNECTED} not found175248.568 9 16 6 hanging up 1st leg of call (other leg cause)175248.568 9 16 6 q_scr + cmdHangupCall 0 So it looks like system behaved as expected, and perhaps what is needed here is for module [switch_disconnect_recorded_call] to have the following path added to it:: on {1} goto [someModule] This would then allow for that module to react to DTMF "1" keypress. Share this post Link to post
invoso.com Report post Posted 10/11/2016 06:47 AM Hi, Problem is VG not reacting on OTHER_LEG_1 we don't know why but recognizing as calling line tones? Each dtmf tone showed above was generated by other_leg not calling one. Problem is we use some dtmf commands on other_leg (agent line) to decide about next process (step) in script and we need to protect script against action by caller side (accidental, unexpected key pressing or receiving dtmf tone) Share this post Link to post
SupportTeam Report post Posted 10/11/2016 07:51 AM Did you need port 34 to do something when DTMF "1" was pressed on port 6 ? There was no script started on port 34, so there was no script running on the outgoing leg of the call transfer/bridge (over port 34) that could react to any events that were sent to port 34. If you would like to start a VoiceGuide script on the outgoing leg of the call please use the Script_Goto function on that channel. More information on Script_Goto: http://www.voiceguide.com/vghelp/source/html/com_script_goto.htm Share this post Link to post
invoso.com Report post Posted 10/11/2016 01:17 PM Dear Support Team. Problem is that port 6 not reacting on dtmf signalisation on port 34. VG should recognizing OTHER_LEG_1 on port 6 not (1) when I press 1 on port 34. But VG see 1 from port 34 as 1 on port 6. It looks as VG not recognizing DTMF tones on OTHER_LEG_() Share this post Link to post
SupportTeam Report post Posted 10/12/2016 06:21 AM The conversation on that bridged call is being recorded, and the 'voice device' from port 6 is being used to record both sides of the call. So port 6's 'voice device' can hear both sides of the call and will report any DTMFs hears on either side. If this call: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_1], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "C:\callrecord\$RV[session_id]_$RV_HH$RV_NN$RV_SS.wav", "") was changed to: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_2], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "C:\callrecord\$RV[session_id]_$RV_HH$RV_NN$RV_SS.wav", "") then port 34's 'voice device' would report any DTMFs, and the DTMF events would be raised from port 34. If you do not want for the 'voice device' that is doing the 2-line recording to report any DTMF tones, but want to be able to detect DTMF tones from separately from each side of the conversation, it may be possible to set that up, but it requires more 'voice device' resources to be added to the system would be a custom solution. Share this post Link to post
invoso.com Report post Posted 10/12/2016 08:36 AM You mean, during recorded call first argument vg.Record_2Lines_Start($RV[Conf_LineId_2] determine line to be sensitive for dtmf signaling (or any other activity?) After stop recording line and disconnecting $RV[Conf_LineId_2] line $RV[Conf_LineId_1] will be again sensitive and can receive and acting on client dtmf tones? Share this post Link to post
invoso.com Report post Posted 10/12/2016 09:12 AM Sorry, but without call recording is this same. $RV[Conf_LineId_2] is completely deaf on any dtmf tones! in case caller pressing 1 log file shows: 105615.656 22 40 14 q_scr + evScriptEvent 49 1105615.656 22 93 31 q_scr + evScriptEvent 49 OTHER_LEG_1 when Agent pressing any dtmf tone VG not showing any data in log file. Please fix it ASAP v7.5.6058.32621 (02-Aug-16 17:07:21.55) Share this post Link to post
SupportTeam Report post Posted 10/12/2016 12:44 PM On our test systems we are seeing that if call recording is in place then the line/device that is recording the conversation sees DTMFs from both parties, and, furthermore, the other line/device continues to see DTMFs pressed on that line as well. And on our test systems both lines raise OTHER_LEG events on the other channel that is bridged. The traces provided at beginning of this thread look as if they are showing DTMFs just being pressed by original caller on the line that is doing the recording (and then the OTHER_LEG is raised on the outgoing leg). Is it possible that the telephone used by the person attached to the outgoing leg of the call (the leg that is not doing the recording) is just not sending any DTMFs or that they are distorted to the point of not being detected by the Dialogic card? In the traces posted at beginning of this thread who is the 'agent'? is 'agent' the person at number 502131658 that was dialed on port 34 ? Who is pressing all these DTMF 1 on that call? The 'agent' or the customer' ? If customer' is pressing all these DTMF 1s then why do they keep on pressing that key? Or is this just a test call and both parties are pressing keys during this connection? That call was recorded into file C:\callrecord\ID20161010_175145_41_6_70320_175200.wav Can you please post that recording ? Share this post Link to post
invoso.com Report post Posted 10/12/2016 01:04 PM As You wish. ID20161010_175145_41_6_70320_175200.wav Share this post Link to post
invoso.com Report post Posted 10/12/2016 01:19 PM Hi, In our system any dtmf tone on Agent side is not detected by VG. If You want I can send You access number and redirect call to other your number to test. Only on caller line VG detecting dtmf signaling (but both sides hear dtmf tone). Share this post Link to post
invoso.com Report post Posted 10/12/2016 02:00 PM connection between line 18 and 33 dtmf send by line 33 shown on log: 155043.290 22 52 18 ev dtmf 1 (43516177,49,0) iConferenceOtherLegLid=98, iConferenceOtherLegIvrDevPort=33 155043.290 22 52 18 q_scr + evScriptEvent 49 1 155043.290 22 98 33 q_scr + evScriptEvent 49 OTHER_LEG_1 155043.290 9 52 18 q_scr run evScriptEvent sCode=[1] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00 max:9|00:00:00.0430025 155043.290 9 52 18 se 1 49 0|0|0 || LineState=LS_GETNBRS_RXDIGITS 155043.290 9 52 18 LsGetNbrsRxDigits lCode=49 lCode2Str=1 sCode=1 155043.290 9 52 18 state [switch_disconnect_recorded_call] Number Input 1 155043.290 9 52 18 path {1} not found 155043.290 9 52 18 t timer set 7200 sec : EV_TIMEOUT_GOTOMODULE 155043.290 9 52 18 not asr event 155043.290 9 98 33 q_scr run evScriptEvent sCode=[OTHER_LEG_1] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00 max:9|00:00:00.0430025 155043.290 9 98 33 se OTHER_LEG_1 49 0|0|0 || LineState=LS_XFER_9_WAITENDCALL_DialingSide 155043.290 9 98 33 LsXfer_9_WaitEndCall_OutLeg : [49:OTHER_LEG_1] 0,0,0 ,, Paths in module has option for {OTHER_LEG_1} not for {1} to eliminate caller (client) activity durring conversation. it mean VG not identify line which is source of dtmf tone? Share this post Link to post
SupportTeam Report post Posted 10/13/2016 01:37 AM ID20161010_175145_41_6_70320_175200.wav recording shows that only the the DTMF 1 key-presses (697Hz+1209Hz) were heard by the system on that connected call. VoiceGuide traces show that those key-presses must have been made by the person that was on port 6 of the call (the caller/client). No sound of any key-presses made by party on port 34 (agent) were heard. If party on port 34 (agent) did press some keys during that call then you should look at the equipment used by the agent and any equipment in between the agent and the Dialogic card in VoiceGuide system. If VoIP/SIP used on any part of that connection then you may want look at that the VoIP/SIP media converting equipment first. Those media converters often clamp DTMF tones and/or do not re-generate them correctly. As a test of what is and isn't heard by the system please do the following: Once call is connected and the recording started have the caller/client party say something and then press key "1", and then have the agent say something and then press key "2". Then post all the VoiceGuide logs and the recording of that conversation. This will give clear picture of what is heard on the line and what events are generated. A second test could be done by changing strRet = vg.Record_2Lines_Start($RV[Conf_LineId_1], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "C:\callrecord\$RV[session_id]_$RV_HH$RV_NN$RV_SS.wav", "") to: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_2], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "C:\callrecord\$RV[session_id]_$RV_HH$RV_NN$RV_SS.wav", "") and then again have the client call in, and, once transfer is connected and the recording started, have the caller/client party say something and then press key "1", and then have the agent say something and then press key "2". This will allow you to compare how the generated events are different depending on which voice device was used for recording. NB. Using: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_1], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "C:\callrecord\$RV[session_id]_$RV_HH$RV_NN$RV_SS.wav", "") is the right option if you want to be able to identify that the DTMF came from agent leg. Share this post Link to post
invoso.com Report post Posted 10/13/2016 08:35 AM Hi, previous test showing no matter option recording or not. VG is not recognizing dtmf signaling side (dtmf signals on $RV[Conf_LineId_2] are same as on $RV[Conf_LineId_1]) and is not recognizing OTHER_LEG_1 on $RV[Conf_LineId_1] Share this post Link to post
SupportTeam Report post Posted 10/13/2016 08:49 AM Please perform the outlined tests and post traces and recordings. Please ensure that, as advised, during each of the test calls : first one party speaks and presses a key, and then another party speaks and presses a key. Share this post Link to post
invoso.com Report post Posted 10/13/2016 11:23 AM As you wish. 1. first call with recording any dtmf from each side viewed on line 1 (1212) 2. second call without recording In case 1. in log file VG see any dtmf activity but in wrong lines (any dtmf on 31 line is identified as dtmf on 1 line) 595 125206.726 5064 3 ev idx=169 : evttype=134(134), crn=0, data=045EEE78(09ED1260), len=4(4) q: 0/9 596 125206.726 5064 3 ev TDX_CST (CST Event Received) 597 125206.726 5064 3 TDX_CST DE_DIGITS data=50 [2], KeysUsed=0 598 125206.726 5064 2 Event_Dtmf iParam1=0x32 iParam2=0x0 599 125206.726 5064 2 r dtmf 2 In case 2. in log is hole between 125420.052 17 2 1 ws do not check iRunWait status as !bCanFireModuleCompletedEvent 125434.073 21 2 1 ev dtmf 1 (41943122,49,0) iConferenceOtherLegLid=93, iConferenceOtherLegIvrDevPort=31 this dtmf 1 was on client line, but previous I send dtmf 1 and dtmf 2 and no trace about this tones. 1013_ktTel.zip ID20161013_124852_41_1_50020.mp3 1013_1250_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 10/13/2016 11:41 AM Please post this recording: C:\callrecord\ID20161013_125118_41_1_50020_125143.wav (the above recording is what was made while the posted 1013_1250_vgEngine trace was running) The posted ID20161013_124852_41_1_50020 recording would have been captured in the vgEngine trace prior to the 1013_1250_vgEngine.txt log. Please post that prior vgEngine log as well if possible. Share this post Link to post
SupportTeam Report post Posted 10/13/2016 11:57 AM Both the recordings: ID20161013_124852ID20161013_125118 appear to be made using this recording command: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_1], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "C:\callrecord\$RV[session_id]_$RV_HH$RV_NN$RV_SS.wav", "") Could you please make a test on your system that uses this command instead: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_2], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "C:\callrecord\$RV[session_id]_$RV_HH$RV_NN$RV_SS.wav", "") and post the recording and traces as before. Share this post Link to post
SupportTeam Report post Posted 10/13/2016 12:36 PM Right now the traces from your system show that tone detection does not seem to work on Voice device attached to port 31 (dxxxB9C1). On our test systems all ports are detecting DTMFs correctly, so more investigation is required to establish what is happening on your system. Suggest testing this card by making outgoing calls on a number of ports to confirm which ports work and which ports do not: Can you please use the Dialer to place a call on port 31 (dtiB2T1) to the agent's telephone, and just run any script that accepts any DTMF digit input (eg. the Credit Card Payment demo script) This will test if port dtiB2T1 and the voice device associated with it (dxxxB9C1) actually detects any DTMF tones at all... Probably a good idea to make a number of these calls on different channels on the the seconds E1 trunk - so ports 31-60 and see which ones work and which ones do not. Also, instead of making all the agent side outgoing calls go out on ports 31-60, try doing a test where the outgoing agent leg of the call goes out on a port that we can see has detected DTMFs before, eg: port 2 So the incoming call is on port 1 (dtiB1T1) and outgoing call is on port 2 (dtiB1T2). We can see that port 2's voice device (dxxxB1C2) can detect DTMF tones - so using that port for the outgoing leg of the call will hopefully result in same performance as we are seeing here on our test systems - where DTMF detection on the outgoing call leg is working fine. Also, please run this Dialogic application: its_sysinfo.exe and post it's output here. also please post VoiceGuide's Config.xml and ConfigLine.xml configuration files. Once we can see the its_sysinfo.exe system configuration report, and VoiceGuide config files, we can advise if anything there needs to be changed. Share this post Link to post
invoso.com Report post Posted 10/14/2016 11:40 AM Completely new server with newest VG (evaluation mode) its_sysinfo.zip ID20161014_132348_43_1_50020.mp3 vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 10/14/2016 12:46 PM Could you please post the ktTel trace as well. Share this post Link to post
invoso.com Report post Posted 10/14/2016 03:45 PM as you wish. 1014_ktTel.zip Share this post Link to post
SupportTeam Report post Posted 10/15/2016 07:59 AM What is playing that female "please hold on line" voice prompt in the ID20161014_132348_43_1_50020 recording? Is the female prompt played by the system that answered the dialed 502131638 number? The male voice in that recording is the caller/client, right ? 132348.165 23 2 1 ev CallState GCEV_OFFERED, crn=2800021, iEvent=0 ,2,0,8, s1:502131638|, s2:221623299, s3: l ! 502131638p 221623299} ]. build_date: 24-Aug-16 14:02:12.73 132348.166 9 2 1 state <offered> : cid=502131638 , dnis=221623299 132358.471 23 2 1 ev dtmf 2 132439.379 9 4 2 ktTel_MakeCall_Enqueue([502131638],DX_PVDENABLE, 60,0,2,502131638,<calltype>DialAndConf</calltype><CallerId>502131638</CallerId><RV>[CDR_user]{ID20161014_132348_43_1_50020}</RV>) call 132446.540 23 4 2 ev CallState GCEV_CONNECTED, 132446.542 9 2 1 TwoCalls_Bridge 2<=>4 (dtiB1T1<=>dtiB1T2) 132446.542 9 2 1 q_tel + cmd_PlayStop [0,0,0,0,0][||||] 132446.543 9 2 1 state [Transfer Call fa with CALLER ID] in_leg 1 <=> 2 502131638 132446.543 9 4 2 state [Transfer Call fa with CALLER ID] out_leg 1 <=> 2 502131638 132446.549 30 2 1 rem Record_2Lines_Start [2,2,4,C:\callrecord\ID20161014_132348_43_1_50020_132446.wav] options=[] 132446.550 23 2 1 ev PlayEnd 2 821721 [bytes_played:56144:56144, bytes_in_file1009999] 132451.111 23 2 1 ev dtmf 1 132451.341 23 2 1 ev dtmf 1 132451.986 23 2 1 ev dtmf 1 132452.291 23 2 1 ev dtmf 1 132452.551 23 2 1 ev dtmf 1 132502.786 23 2 1 ev dtmf 2 132503.181 23 2 1 ev dtmf 2 132503.831 23 2 1 ev dtmf 2 132504.201 23 2 1 ev dtmf 2 132513.337 23 2 1 ev dtmf 2 132515.122 23 2 1 ev dtmf 2 132517.292 23 4 2 ev CallState GCEV_DISCONNECTED, crn=2800023 Share this post Link to post
