Line Status Monitor Not Showing Outbound Call
line status monitor in previous versions show outbound call information on before connected with target number. Now (7.5.6 aka 7.5.7) show only after connecting with target number. Can You to fix it as before, because in this case we see what happen on each port (channel) before connection (show => )
The numbers dialed still should show in the Line Status app.
Could you please post traces capturing the outgoing call.
We can then see what is happening on the outgoing calls.
