Wrong Handle Of "vg.run_Resultreturn" ?
we use VoiceGuide version 7.5.7 on Windows 2012 with Dialogic HMP Software driver
It works well.
But there is something that i don't understand. Below i posted a sample script, it is a sample extract from a more dfficult script, but it describes the problem.
The Script does not end in the failed path, it always plays xxx.wav
I'm not sure what goes wrong?
Regards,
Sebastian
Version=5.0
DefaultModuleDisplayHeight=
StartModule=Erfolg
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[test]
Type=Run VB Script
DispSize=69
Txt=Run a VB Script.
VbsFileToRun=
VbsWait=1
VbScript=
MSB = "fail"
if 1 = 2 then
MSB = "success"
else
MSB = "fail"
end if
vg.Run_ResultReturn $RV_LINEID, MSB
set vg = Nothing
VbsHoldPlay=
on {fail} goto [Fehler]
on {success} goto [Erfolg]
on {timeout 0} goto [TimeOut]
Position=118,160
[Erfolg]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
PlayFile1=xxx.wav
Replay=2,5
strTtsText=
on {timeout 0} goto [auflegen]
Position=206,299
[Fehler]
Type=Play
DispSize=69
PlayFile1=xx.wav
Replay=2,5
strTtsText=
Position=465,297
[TimeOut]
Type=Play
DispSize=69
PlayFile1=x.wav
Replay=2,5
strTtsText=
Position=676,295
[auflegen]
Type=Hangup the Call
DispSize=69
Txt=Hangup the call.
Position=518,526
Could you please post the vgEngine trace for your system that captures the system startup and the call running the scirpt.
We can then see what is happening on our system and why it is behaving the way it is behaving.
