jiaseby Report post Posted 12/20/2016 05:55 PM After I query a database and get a field that is a date field, I need to add 14 days to it. Not sure how to do this. I'm guessing in an evaluate expression, but I'm having no luck. Share this post Link to post
SupportTeam Report post Posted 12/20/2016 09:25 PM Could you please post VoiceGuide's vgEngine trace that captures the database query. We can then see in what format the date is returned and can then advise on how 14 days can be added to it. Share this post Link to post
jiaseby Report post Posted 12/21/2016 03:34 PM Here is the log file. The result var I'm trying to assign is dateplus14. You will see this on or about line 093059.897. you can see the way I tried didn't work. Thanks Share this post Link to post
SupportTeam Report post Posted 12/21/2016 07:38 PM No log file was attached. Can you please try attaching the log file again. Share this post Link to post
jiaseby Report post Posted 12/23/2016 04:58 PM Sorry I thought I attached it. Share this post Link to post
SupportTeam Report post Posted 12/23/2016 05:06 PM Still nothing attached... Can you try .ZIPing up the file and attaching the .ZIP version ? Share this post Link to post
jiaseby Report post Posted 12/23/2016 08:14 PM Line 141205:796 1223_1411_vgEngine.txt Share this post Link to post
SupportTeam Report post Posted 12/23/2016 10:21 PM Trace shows that query: SELECT check, amount,idate,issued FROM Check WHERE check.check=123 results in following RVs being set for idate value retrieved: 141155.387 4 5 3 rv add SQLCheck2_idate|12/21/2016 12:00:00 AM141155.387 4 5 3 rv add SQLCheck2_3|12/21/2016 12:00:00 AM141155.388 4 5 3 rv add SQLCheck2_idate_1|12/21/2016 12:00:00 AM141155.388 4 5 3 rv add SQLCheck2_3_1|12/21/2016 12:00:00 AM $RV[sqlCheck2_3_1]stores the string "12/21/2016 12:00:00 AM" - to which 14 days need to be added. Suggest looking at the VBScript function DateAdd: http://www.w3schools.com/asp/func_dateadd.asp please try using a "Run VBScript" module to run the below VBScript and post traces capturing the call. set vg = CreateObject("vgServices.CommandLink") sNewDate = DateAdd("d",14,"$RV[sqlCheck2_3_1]") vg.Run_ResultReturn $RV_LINEID, "[NewDate]{" & sNewDate & "}"set vg = Nothing Share this post Link to post
jiaseby Report post Posted 12/26/2016 07:13 PM I didn't post the log because it worked perfect. Thank you. Share this post Link to post
