jiaseby Report post Posted 12/26/2016 06:44 PM I'm pulling data from a table that is a date field. I want to test if the field has a date in it or not. It is a table with check information. One of the fields is "Cleared". If it is blank that means the check is still outstanding. However when I look at the field I see it has a date in it when it's blank. The date is 12/30/1899 12:00:00 AM. Can you tell how I test for this? It is the data in SQLCheck_4_1 in the engine log attached. 1226_1237_vgEngine.txt Share this post Link to post
SupportTeam Report post Posted 12/27/2016 08:53 AM From the trace we can see that you are on the right track by using an Evaluate Expression type module to check whether date is 12/30/1899 12:00:00 AM But as the $RVs are all stored as 'Strings', the comparison expression must use quotes, like this: "$RV[sqlCheck_4_1]" = "12/30/1899 12:00:00 AM" right now that Evaluate Expression module errors because quotes are not used: 123750.114 9 5 3 state [ClearDate] Evaluate [$RV[sqlCheck_4_1] = 12/30/1899 12:00:00 AM]123750.114 9 5 3 rv replace start [$RV[sqlCheck_4_1] = 12/30/1899 12:00:00 AM]123750.114 9 5 3 rv replace end [12/30/1899 12:00:00 AM = 12/30/1899 12:00:00 AM]123750.114 9 5 3 eval [12/30/1899 12:00:00 AM = 12/30/1899 12:00:00 AM]123750.115 9 5 3 VGMTYPE_EVALEXPR InvokeMember Eval Exception : Exception has been thrown by the target of an invocation. Share this post Link to post
