Problems With D/21d Card
Hi!
I have, as stated on the website, converted all sound files to mu law files.
But the same problem is still there:
Voice guide hangs up straight after answering a call, without running any voice files. I even tried it by replacing my voice files with the voice MuLaw 8kHz 8bit Mono files I downloaded from your website.
any help to solve the problem is much apreciated!
Here is a copy of the event trace log:
194346,00 0 dial callque update id=10 next call time 0403052143
194347,01 5 dial found entry: tel[219739] ann[NONE] vgs[C:\Programme\VoiceGuide\Scripts\VGCalltocustomer,reg[1].0900.vgs] am[C:\Programme\VoiceGuide\Scripts\VGCalltocustomer,reg[1].0900.vgs]
194347,01 5 Dialing: 219739
194347,02 5 MakeCall => 66459
194347,02 5 TapiCbTrigSet 66459 7002
194347,83 5 tapi Reply 66459 0
194347,83 5 TapiCbTrigClear
194347,84 5 linedevstate 2048 0 0
194347,84 5 callstate DIALTONE 66118 0 0
194347,85 5 callstate DIALING 66118 0 0
194347,85 5 callstate PROCEEDING 66118 0 0
194347,86 5 callinfo CALLEDID
194347,86 5 callinfo REASON
194347,87 5 Lev_CallerID [0000,]
194347,87 5 callinfo ORIGIN
194352,34 5 callstate CONNECTED 66118,1,0
194352,36 5 WorkingModeTAPI=
194352,37 5 WorkingModeScript=
194352,43 0 dial callque delete id=10
194352,47 5 Live person answered, starting C:\Programme\VoiceGuide\Scripts\VGCalltocustomer,reg[1].0900.vgs
194352,50 2 tr NewVgsVgm_Goto C:\Programme\VoiceGuide\Scripts\VGCalltocustomer,reg[1].0900.vgs,,,,,0
194352,54 0 LoadedVgs_Find C:\Programme\VoiceGuide\Scripts\VGCalltocustomer,reg[1].0900.vgs at idx=1
194352,57 5 cl NewVgsVgm_RunModule module not found:
194352,61 2 tr NewVgsVgm_Goto 1
194352,64 2 tr NewVgsVgm_Goto 2
194352,68 5 [Play 0] Playing
194352,72 5 [Play 0] Playing (C:\voice files\voice MuLaw\Voicemail Server\VmailSysWelc.wav)
194352,79 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32] file[C:\voice files\voice MuLaw\Voicemail Server\VmailSysWelc.wav]
194352,88 5 PlaySoundStart line[5] err=[0 wavec waveOutOpen(0x0, 0x0, 0x3af4850, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [C:\Programme\VoiceGuide\system\voice\ErrorPlayingFile.wav]
194352,91 5 For Dialogic use: PCM 11Khz 8bit Mono
194352,94 5 Hanging up call... [srlib PlaySoundStart]
194352,98 5 RecSoundStop ok
194353,01 5 PlaySoundStop ok
194353,05 5 fnHangupCall end
194353,08 5 RunModule PLAY end
194353,11 2 tr NewVgsVgm_Goto end
194353,15 5 tapie PlayEnd old line=5 0 611517
194353,18 5 tapie PlayEnd old line=5 0 611517
194353,23 5 linedevstate 2048 0 0
194353,26 5 callstate IDLE 66118 0 0
194353,29 5 WorkingMode@Idle=
194353,33 5 tapi Reply 66033 0
194354,27 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
194354,31 5 ReinitTelephony due to IDLE start
194354,35 5 tapic lineDeallocateCall(MainCall:66118) 0
194354,58 5 lineOpen(5) => 0
194354,61 5 Waiting for a call...
194354,65 5 lineOpen(5)LineHandle=66169
195125,17 5 linedevstate 2048 0 0
195125,22 5 callstate OFFERING 66271 0 4
195125,27 5 callinfo CALLEDID
195125,30 5 callinfo ORIGIN
195125,35 5 ring 0
195131,20 5 ring 2
195131,23 5 Answer the call at 05.03.2004 19:51:31
195131,27 5 lineAnswer(66271) => 66015
195131,82 5 callstate CONNECTED 66271,1,0
195131,84 5 WorkingModeTAPI=
195131,89 5 WorkingModeScript=
195131,95 5 Inband detection not enabled
195131,00 5 StartLoadedVgs at 05.03.2004 19:51:31
195132,02 5 tapi Reply 66015 0
195132,09 5 [Play 0] Playing
195132,13 5 [Play 0] Playing (C:\voice files\voice MuLaw\Voicemail Server\VmailSysWelc.wav)
195132,17 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32] file[C:\voice files\voice MuLaw\Voicemail Server\VmailSysWelc.wav]
195132,21 5 PlaySoundStart line[5] err=[0 wavec waveOutOpen(0x0, 0x0, 0x3af4850, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [C:\Programme\VoiceGuide\system\voice\ErrorPlayingFile.wav]
195132,25 5 For Dialogic use: PCM 11Khz 8bit Mono
195132,28 5 Hanging up call... [srlib PlaySoundStart]
195132,30 5 RecSoundStop ok
195132,35 5 PlaySoundStop ok
195132,38 5 fnHangupCall end
195132,42 5 RunModule PLAY end
195132,45 5 tapie PlayEnd old line=5 0 70928
195132,48 5 tapie PlayEnd old line=5 0 70928
195133,88 5 linedevstate 2048 0 0
195133,91 5 callstate IDLE 66271 0 0
195133,95 5 WorkingMode@Idle=
195133,99 5 tapi Reply 66050 0
195134,89 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
195134,92 5 ReinitTelephony due to IDLE start
195134,96 5 tapic lineDeallocateCall(MainCall:66271) 0
195135,20 5 lineOpen(5) => 0
195135,22 5 Waiting for a call...
195135,25 5 lineOpen(5)LineHandle=66101
195236,77 5 linedevstate 2048 0 0
195236,80 5 callstate OFFERING 66510 0 4
195236,85 5 callinfo CALLEDID
195236,89 5 callinfo ORIGIN
195236,92 5 ring 0
195242,79 5 ring 2
195242,82 5 Answer the call at 05.03.2004 19:52:42
195242,86 5 lineAnswer(66510) => 65811
195243,40 5 callstate CONNECTED 66510,1,0
195243,43 5 WorkingModeTAPI=
195243,47 5 WorkingModeScript=
195243,54 5 Inband detection not enabled
195243,57 5 StartLoadedVgs at 05.03.2004 19:52:43
195243,61 5 tapi Reply 65811 0
195243,64 5 [Play 0] Playing
195243,68 5 [Play 0] Playing (C:\voice files\voice MuLaw\Voicemail Server\VmailSysWelc.wav)
195243,72 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32] file[C:\voice files\voice MuLaw\Voicemail Server\VmailSysWelc.wav]
195243,76 5 PlaySoundStart line[5] err=[0 wavec waveOutOpen(0x0, 0x0, 0x3af4850, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [C:\Programme\VoiceGuide\system\voice\ErrorPlayingFile.wav]
195243,79 5 For Dialogic use: PCM 11Khz 8bit Mono
195243,83 5 Hanging up call... [srlib PlaySoundStart]
195243,86 5 RecSoundStop ok
195243,90 5 PlaySoundStop ok
195243,93 5 fnHangupCall end
195243,97 5 RunModule PLAY end
195244,00 5 tapie PlayEnd old line=5 0 142481
195244,03 5 tapie PlayEnd old line=5 0 142481
195245,43 5 linedevstate 2048 0 0
195245,46 5 callstate IDLE 66510 0 0
195245,50 5 WorkingMode@Idle=
195245,55 5 tapi Reply 65913 0
195246,45 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
195246,48 5 ReinitTelephony due to IDLE start
195246,52 5 tapic lineDeallocateCall(MainCall:66510) 0
195246,74 5 lineOpen(5) => 0
195246,77 5 Waiting for a call...
195246,81 5 lineOpen(5)LineHandle=65862
Hi!
I tried reinstalling wav driver, but still get same error:
what does inband detection not enabled mean...is that maybee the problem?
any help is much apreciated...
regards
Alex
222104,07 5 linedevstate 2048 0 0
222104,08 5 callstate OFFERING 66133 0 4
222104,11 5 callinfo CALLEDID
222104,12 5 callinfo ORIGIN
222104,12 5 ring 0
222110,18 5 ring 2
222110,18 5 Answer the call at 07.03.2004 22:21:10
222110,19 5 lineAnswer(66133) => 66116
222110,73 5 callstate CONNECTED 66133,1,0
222110,73 5 WorkingModeTAPI=
222110,75 5 WorkingModeScript=
222110,79 5 Inband detection not enabled
222110,83 5 StartLoadedVgs at 07.03.2004 22:21:10
222110,84 5 tapi Reply 66116 0
222110,85 5 [Play 1] Playing
222110,86 5 [Play 1] Playing (C:\voice files\converted voice files, receiving\1.wav)
222110,96 5 File not found [C:\voice files\converted voice files]
222111,07 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32] file[C:\Programme\VoiceGuide\system\voice\SoundFileNotFound.wav,C:\Programme\VoiceGuide\system\voice\1.wav]
222111,13 5 PlaySoundStart line[5] err=[0 wavec waveOutOpen(0x0, 0x0, 0x3af4850, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [C:\Programme\VoiceGuide\system\voice\ErrorPlayingFile.wav]
222111,17 5 For Dialogic use: PCM 11Khz 8bit Mono
222111,21 5 Hanging up call... [srlib PlaySoundStart]
222111,24 5 RecSoundStop ok
222111,27 5 PlaySoundStop ok
222111,31 5 fnHangupCall end
222111,33 5 RunModule PLAY end
222111,37 5 tapie PlayEnd old line=5 0 736779
222111,39 5 tapie PlayEnd old line=5 0 736779
222112,76 5 linedevstate 2048 0 0
222112,79 5 callstate IDLE 66133 0 0
222112,82 5 WorkingMode@Idle=
222112,91 5 tapi Reply 66099 0
222113,84 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
222113,88 5 ReinitTelephony due to IDLE start
222113,91 5 tapic lineDeallocateCall(MainCall:66133) 0
222114,13 5 lineOpen(5) => 0
222114,16 5 Waiting for a call...
222114,18 5 lineOpen(5)LineHandle=66082
Can you try installing v5.2.1 - that version will generate some more debugging which may help us with seeing exactly where the problem lies.
(although I'm pretty sure it's with the wave drivers)
Inband detection is something different - its optional communication from the switch which can be sent at beginning of call and can carry info like what number caller rung etc.
