ID2016 Report post Posted 03/13/2017 04:36 PM After conversion from Vg6 to Vg7 voip when I ran the same vgs script, the queid was updated with -1 value in calltrack table and no script playing when phone rings. I resinstalled sql stored procedure for the database as it was requested above and it fixed the table creation issue. But now there is a different problem. Please check the logs. 0306_ktTts.zip IvrPin.zip Share this post Link to post
SupportTeam Report post Posted 03/14/2017 09:31 AM The -1 in calltrack's "queid" field is probably related to the disabling of the "porttouse" table on this system by setting zConfigXml_sDialer_OutDialQue_porttouse_LinkField entry to Disable in the Config.xml This disables ability to select the specific port(s) on which the loaded outgoing call can be made out on, and looks like disabling this affected the calltrack table as well. In the version you have on system right now the "PortToUse_LinkField" in Config.xml would have needed to be set to "ID" in order for the ID to be used to link up all the different entries, but perhaps the GUID fields are synced up between the callque and calltrack tables and you can use those to if you want to link up the entries in different tables? Easiest may be to just update system with vgDialListLoad attached to this post. This version fixes the insert so that both ID and GUID are saved in the calltrack table when the zConfigXml_sDialer_OutDialQue_porttouse_LinkField entry is set to Disable in the Config.xml To update just unzip and place .exe in VoiceGuide directory. (backup/rename previous vgDialListLoad.exe first) vgDialListLoad_7.5.8_170314.zip Share this post Link to post
ID2016 Report post Posted 03/14/2017 04:19 PM This advice broke loader completely. Even when I reversed to the original loader, its not working anymore. What do i need to do now? Share this post Link to post
SupportTeam Report post Posted 03/14/2017 09:14 PM Could you please advise waht isn't working on this system? Does the Call Loader application start? Are the calls being loaded into the database? Please try running both versions of Telephone Number Loader (one at a time) and then .ZIP up and post the DialListLoad traces from VoiceGuide's directory. We can then see what is happening on the system. Share this post Link to post
ID2016 Report post Posted 03/16/2017 03:49 AM I need help asap. Weare going live in a few days but I cannot make any calls anymore after I installed recommende loaded . Old loader produce the same error. Please see an attachment - both loader generate the same error. I am attaching error logs, vg.ini, config, mysql stored procedure with insert statement. I was given trial license for 4 VOIP lines that expires soon. Please provide clear plan how i can fix VG. My insert statement inserts data into outdialque table but nothing is working. This is my sql stored pr: CREATE DEFINER=`root`@`localhost` PROCEDURE `readPin`(IN ivrPhone VARCHAR(11) , IN ivrPin VARCHAR(20), IN ivrSite VARCHAR(20)) BEGIN insert into callque (phonenumber, phonenumberprefix, activatetime, TimeStart_Mon,TimeStop_Mon,TimeStart_Tue,TimeStop_Tue,TimeStart_Wed,TimeStop_Wed, TimeStart_Thu ,TimeStop_Thu ,TimeStart_Fri,TimeStop_Fri, TimeStart_Sat,TimeStop_Sat,TimeStart_Sun,TimeStop_Sun, campaignname, priority, onanswerlive, onanswermachine, onnotanswered, onretriesexhausted, answertimeout, retriesleft, retriesdelay, rv, calloptions, escalationcalls) values(ivrPhone, '9', curdate(), 1,2359,1,2359,1,2359,1,2359,1,2359,1,2359,1,2359, 'MyHealthPin', 1, 'C:\\Program Files (x86)\\VoiceGuide\\Scripts\\ReadPin\\IvrPin.vgs', 'C:\\Program Files (x86)\\VoiceGuide\\Scripts\\ReadPin\\IvrPin.vgs', '', '', 60, 1, 10, '[ivrPhone]{'+ivrPhone+'}[ivrPin]{'+ivrPin+'}[ivrSite]{'+ivrSite+'}', '', ''); END 0314_ktTts.zip error_message.zip Share this post Link to post
SupportTeam Report post Posted 03/16/2017 11:03 AM Traces show outgoing calls are attempted, but the numbers loaded do not have the @IPADDRESS appended to them. We can see in traces this: Line 590: 225217.711 9 3 1 state Dialing (auto) 92489789145 Line 747: 225317.053 9 3 1 state Dialing (auto) 912489789145 Line 641: 232434.395 9 3 1 state Dialing (auto) 912489789145 Line 803: 232440.483 9 3 1 state Dialing (auto) 912489789145 Line 935: 232441.504 9 3 1 state Dialing (auto) 912489789145 Line 1067: 232442.522 9 3 1 state Dialing (auto) 912489789145 Line 1198: 232443.535 9 3 1 state Dialing (auto) 912489789145 please ensure number specified is a fully qualified VoIP number with the IP address appended. Regarding the loader application, please stop VoiceGuide service and exit all programs and then and delete the vgDialListLoad.exe from VoiceGuide directory. Once deleted the please the install of the latest version of VoiceGuide over the top of current install. This will ensure the vgDialListLoad.exe as included in VoiceGuide distribution ins placed on your system. Still it looks like your insert SQL will be fine once the number is fixed up, so you may not need to use the vgDialListLoad.exe to load the calls anyway. Share this post Link to post
ID2016 Report post Posted 03/16/2017 03:23 PM I do not not understand you response about @IPADDRESS. The config file has all this info. I have 4 ipaddresses for VOIP. What is missing? Did you look into my config.xml? Share this post Link to post
SupportTeam Report post Posted 03/16/2017 06:05 PM Please see: http://voiceguide.com/forums/index.php?showtopic=12342&p=42031&do=findComment&comment=42031 When loading a VoIP call into system you need to specify through which VoIP gateway/switch/etc that call is to be sent out through. And the VoIP Switch / PBX / Gateway then forwards that VoIP call on to next VoIP Switch / PBX / Gateway according to its own rules. VoIP number is specified as: number@ipaddress eg: 912489789145@10.231.234.19 10.231.234.19 is the IP address of your VoIP Switch / PBX / Gateway that we can see you have used before. In the traces attached in the first post of this thread (0306_ktTts.zip) we can see that many outgoing calls were made from this system by routing them out through the 10.231.234.19 IP address Share this post Link to post
ID2016 Report post Posted 03/16/2017 09:30 PM 0316_1345_vgEngine.zipBu I have 4 IP addresses -> 4 channels. I can not choose in advance one of them when I insert a record per the phone call in outdialque table. I am using Mysql stored procedure to insert the phone number with RV into outdialque table. It should be able to call using any of 4 IPs designated to voip. How can I assign one? Please see my stored procedure. It has only phone and IP address. You said earlier it should work as it is. Please send me config.xml that I should have if the one I attached is incorrect. insert into callque (phonenumber, phonenumberprefix, activatetime, TimeStart_Mon,TimeStop_Mon,TimeStart_Tue,TimeStop_Tue,TimeStart_Wed,TimeStop_Wed, TimeStart_Thu ,TimeStop_Thu ,TimeStart_Fri,TimeStop_Fri, TimeStart_Sat,TimeStop_Sat,TimeStart_Sun,TimeStop_Sun, campaignname, priority, onanswerlive, onanswermachine, onnotanswered, onretriesexhausted, answertimeout, retriesleft, retriesdelay, rv, calloptions, escalationcalls) values(ivrPhone, '9', curdate(), 1,2359,1,2359,1,2359,1,2359,1,2359,1,2359,1,2359, 'MyHealthPin', 1, 'C:\\Program Files (x86)\\VoiceGuide\\Scripts\\ReadPin\\IvrPin.vgs', 'C:\\Program Files (x86)\\VoiceGuide\\Scripts\\ReadPin\\IvrPin.vgs', '', '', 60, 1, 10, '[ivrPhone]{'+ivrPhone+'}[ivrPin]{'+ivrPin+'}[ivrSite]{'+ivrSite+'}', '', ''); I also downloaded the newer version of VG 7.5.8 - it was changed after I had the issue with Loaded. Attaching logs files. Share this post Link to post
SupportTeam Report post Posted 03/16/2017 10:23 PM There is no need to have an IP address 'per channel' (ie. a separate IP address for each simultaneous call). Many calls can be sent through one "IP Address". Can you please describe your setup in more detail. What device(s) are thse 4 IP adresses assigned to ? Share this post Link to post
SupportTeam Report post Posted 03/16/2017 10:28 PM Also, traces now shows that there are currently issues with your Config.xml file: 134835.022 0 vgDb_ProviderInvariant Db_LoadConfig call 134835.027 ERROR 7.5.6267.23386 Db_LoadConfig xmlConfigFile.Load : The 'Channel' start tag on line 34 position 2 does not match the end tag of 'Channels'. Line 42, position 3. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) at System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag) at System.Xml.XmlTextReaderImpl.ParseEndElement() at System.Xml.XmlTextReaderImpl.ParseElementContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace) at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc) at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at ..() 134835.027 0 config.xml read: /VoiceGuideConfig/Dialer 134835.027 db config SelectNodes(/VoiceGuideConfig/Dialer) returned no nodes so looks like right now the Config.xml cannot be read in, so this system is not even connecting to your MySQL backend database. Pleas check your Config.xml for correct syntax. Share this post Link to post
ID2016 Report post Posted 03/16/2017 11:12 PM 3162017.zip0316_1803_vgDialListLoad.zipI strongly believe there is a problem with newest version VG 7.5.8. No matter what I put into config.xml, the logs have the same error. As result of these actions - replacement telephone loader, installation of VG 7.5.8, I cannot get anything into outdialque table from Loader. Neither I can dial when run stored procedure . Need resolution ASAP. Share this post Link to post
SupportTeam Report post Posted 03/17/2017 12:46 AM The Config.xml now looks fine and the latest traces from the set of provided trace no longer show any Config.xml errors - the early traces in the set: 0316_1346_vgEngine.txt and 0316_1802_vgEngine.txt show the Config.xml error, but the more recent 0316_1826_vgEngine.txt and 0316_1841_vgEngine.txt don't show the config.xml error, and show that connection to MySQL database was done OK: 184106.598 15 Db_Open GetFactory call [MySql.Data.MySqlClient] 184106.601 15 Db_Open sDbName=[outdialque] 184106.601 15 Db_Open CreateConnection call 184106.611 15 Db_Open CreateConnection returned. conn=MySql.Data.MySqlClient.MySqlConnection, this=ktlib.vgDb.vgDb_ProviderInvariant 184106.611 15 Db_Open sConnString in.len=86, rvreplaced.len=87 184106.620 15 Db_Open conn.Open call 184106.727 15 Db_Open conn.Open returned 184106.728 15 Db_TestTables start, conn.DataSource=localhost, Provider=MySql.Data.MySqlClient 184106.728 15 Db_TestTables callque ExecuteScalar SELECT COUNT(*) FROM callque call (default) 184106.732 15 Db_TestTables callque ExecuteScalar SELECT COUNT(*) FROM callque returned iCount=0 184106.732 15 Db_TestTables calltrack ExecuteScalar SELECT COUNT(*) FROM calltrack call (default) 184106.735 15 Db_TestTables calltrack ExecuteScalar SELECT COUNT(*) FROM calltrack returned iCount=66 184106.735 15 Db_TestTables returned ok 184106.735 15 Db_Open DbCommandsParamteresInit next. conn=MySql.Data.MySqlClient.MySqlConnection Two vgDialListLoad traces were included in provided traces: The 0316_1803_vgDialListLoad.txt trace shows that the Dial List Loder app when started at 6:03PM could not read the Config.xml, so would not have connected to the MySQL database, so all the calls loaded between 18:03 and 18:43 using that instance of app were placed into default databsae (SQLite file C:\Program Files (x86)\VoiceGuide\data\vgDb.db) : 180307.865 0 vgDb_ProviderInvariant Db_LoadConfig call 180307.872 ERROR 7.5.6267.23386 Db_LoadConfig xmlConfigFile.Load : The 'Channel' start tag on line 34 position 2 does not match the end tag of 'Channels'. Line 42, position 3. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) at System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag) at System.Xml.XmlTextReaderImpl.ParseEndElement() at System.Xml.XmlTextReaderImpl.ParseElementContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace) at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc) at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at ..() 180307.872 0 config.xml read: /VoiceGuideConfig/Dialer The 0316_1902_vgDialListLoad.txt trace file is missing the startup section, so we cannot see to what database it connected. If there were problems with Config.xml at that time then again this Dial List Load instance would not have connected to the MySQL database. Suggest using MySQL Worbench or other similar tools to confirm if calls are being laded into database thatyou expect them to be loaded. The 'calltrack' table is probably the best palce to monitor new additons made from the Dial List Load app. Share this post Link to post
SupportTeam Report post Posted 03/17/2017 01:01 AM In addition, the 0316_1826_vgEngine.txt and 0316_1841_vgEngine.txt traces show outgoing call attempts, but the were made to numbers that did not even have an IP address in them. So they all failed as could not be VoIP routed: Line 647: 182632.493 9 3 1 state Dialing (auto) 9123462462 Line 770: 182633.507 9 3 1 state Dialing (auto) 9123462462 Line 901: 182634.515 9 3 1 state Dialing (auto) 9123462462 Line 1034: 183632.446 9 3 1 state Dialing (auto) 9123462462 Line 1172: 183633.461 9 3 1 state Dialing (auto) 9123462462 Line 1308: 183635.494 9 3 1 state Dialing (auto) 9123462462 Line 632: 184921.188 9 3 1 state Dialing (auto) 9236463575735 Line 768: 185921.140 9 3 1 state Dialing (auto) 9236463575735 guess the 9123462462 calls were old calls still in database that were getting redialed, and the 9236463575735 call was a new call loaded direct into database (?) The DialListLoad traces show that loaded calls did include IP address, but as per previous post, it looks like these calls were not loaded into the MySQL database: 0316_1803_vgDialListLoad.txt Line 206: 180316.835 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,a3fe0b6c-325f-4e50-a2e0-17cfbffcf5e1,] Line 212: 180316.843 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,b1e695b0-b8fd-4664-ba05-f9965a8f7088,] Line 218: 180316.844 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,ef2d7e8d-cf1a-4eeb-9650-b2fe0fbbb5a2,] Line 224: 180316.845 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,f0d43931-12b7-4694-8649-d02d6c7fb297,] Line 371: 180826.658 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,8ab44e5c-086f-4e29-8df0-7b44165d4fc2,] Line 377: 180826.660 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,05cbac14-43d6-4061-b508-8ff60c4072c5,] Line 383: 180826.661 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,3bf610e2-70c0-433a-ad5b-fe35f554dd4a,] Line 389: 180826.662 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,c9d6bbc5-14ee-4228-8f82-d77883e4ad68,] Line 537: 181207.621 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,d6c0f319-bb42-440e-b2c4-9c4eb3d28c22,] Line 543: 181207.624 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,6a326ba3-dd87-468d-ab6d-75996cc702b2,] Line 549: 181207.624 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,92f223d1-33c5-4425-bb6c-55b6b86ff524,] Line 555: 181207.625 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,7b4efec7-72c3-487b-aa2e-75d063325725,] Line 732: 182638.770 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,c07f4e6a-b734-4059-8b36-4446fd95b9de,] Line 738: 182638.772 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,9e61361d-96cb-4287-a6eb-59d203b8d77a,] Line 744: 182638.773 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,8206400a-4f67-4ddb-8ddc-e2054fe54629,] Line 750: 182638.774 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,2f02b492-4d03-4200-9843-5051804936c5,] Line 912: 183959.246 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,92cdd559-2bd9-4f4d-9dbe-77a9a18bd40d,] Line 918: 183959.248 0 dial cmd_callque_Insert ExecuteNonQuery [912489789145@10.231.234.19,,f559208e-cd53-4967-8f96-14a7957b2553,] etc. 0316_1902_vgDialListLoad.txt Line 106: 190305.395 0 dial cmd_callque_Insert ExecuteNonQuery [92489789145@10.231.234.19,,6e0db6f0-d567-429b-867c-c3cd9e18a1fa,] Line 273: 190341.425 0 dial cmd_callque_Insert ExecuteNonQuery [92489789145@10.231.234.19,,be2186d8-221c-4aec-ada6-473c42e0efc0,] Share this post Link to post
ID2016 Report post Posted 03/17/2017 08:07 PM i was able to fix the issues Share this post Link to post
