Guest ThaoHuynh Report post Posted 03/22/2017 10:24 AM Hi, I have installed Dialogic HMP 7.5, and VoiceGuide 7.5.8. And i also installed the softphone is linphone. When i created account, Linphone team give me these parameters: Sip identity : sip:phuongthaohuynh@sip.linphone.org Username : phuongthaohuynh Domain / Proxy : sip.linphone.org And i use this parameter to modify the config.xml. I attached log file. Please see the attached file. Regards, Thao Huynh Config+ Log.zip Share this post Link to post
SupportTeam Report post Posted 03/22/2017 10:44 AM VoiceGuide's ktTel trace shows an error on Dialogic drivers level: 078 101341.021 4292 ERROR gc_start 079 101341.021 4292 1 ERROR StartDialogicGlobalCall returned -1 Have you tested this HMP installation using Dialogic's own IPMediaServer.exe test application? Please see: http://www.voiceguide.com/vghelp/source/html/install_v7_dialogichmp.htm Looks like Windows 7 SP1 is used on this system: szOSName: Microsoft Windows 7, szOSVersion: 6.1, szOSBuild: 7601, szOSType: , szOSSvcPack: Service Pack 1 Is anything else installed on that system apart from Windows and HMP? Is this perhaps a virtual machine? Share this post Link to post
Guest ThaoHuynh Report post Posted 03/22/2017 11:02 AM I have tested HMP installation. It looks ok. ************************************************************ * * * IP Media Server - Media services over IP Demo Program. * * Copyright ⌐ 2007 Dialogic Corporation. * * * ************************************************************ DTMFMode inband TxCoder[0] Capability: g711mulaw Type: 2 Direction: 1 Payload_type: 255 FramesPerPacket: 20 VAD: 0. RxCoder[0] Capability: g711mulaw Type: 2 Direction: 2 Payload_type: 255 FramesPerPacket: 20 VAD: 0. [info] CEventRouter::Init: Initializing channels...may take a few seconds! <<Number of Fax (& Voice) boards found: 1 >> <<Number of Voice (& Fax boards) found: 1 >> <<Number of IPT boards found: 1>> <<Number of IPM boards found: 1>> Waiting for key: 'Q' - to quit CIPDevice::processEvent -> receive GCEV_UNBLOCKED on :N_iptB1T1:P_IP:M_ipmB1C1 ***************************************************************** What happens when my system is Windows 7 SP1? It's not a virtual machine. Thanks for your reply. Share this post Link to post
SupportTeam Report post Posted 03/22/2017 11:10 AM Should be no issues starting up VoiceGuide then... Is any other software installed on this system apart from Windows+HMP+VoiceGuide? Is there perhaps any other VoIP software installed that could be using the 5060 SIP port? Is all other software closed when the VoiceGuide service is started? Please close or uninstall other software that could be conflicting and try starting VoiceGuide again. Look in VoiceGuide ktTel log and make sure that there are no gc_Start errors like this one after starting the service: 078 101341.021 4292 ERROR gc_start 079 101341.021 4292 1 ERROR StartDialogicGlobalCall returned -1 Share this post Link to post
Guest ThaoHuynh Report post Posted 03/23/2017 03:46 AM Yes, i installed a lot of softwares on this system. I used netstat -atun to check 5060 port is open or close, but it's not diplay although i registered SIP account. Share this post Link to post
SupportTeam Report post Posted 03/23/2017 03:58 AM There are other ports that could be causing issue with Dialogic HMP. These TCP ports must be available: 1719, 1720, 5060, 12002, 12003, 12004, 20000, and 20001 (please see https://www.dialogic.com/-/media/manuals/hmp30win/release_install.pdf ) If you have any anti-virus type software on system we'd recommend disabling it for a while until this HMP startup problem is resolved. Please also .ZIP up all the RTF logs from Dialogic's \log\ sub-directory and post them here. We can then advise if they show what is going wrong. Share this post Link to post
Guest ThaoHuynh Report post Posted 03/23/2017 04:24 AM This is my RTF log. Please check attached file. log.zip Share this post Link to post
SupportTeam Report post Posted 03/23/2017 04:49 AM The RTF log files do not seem to contain enough information about what happened Please try this:1. Stop the VoiceGuide service.2. Stop the Dialogic service.Please place the attached RtfConfigWin.xml file on your system - unzip first. (file link at very bottom of this post)for Windows 7/8.1/10 and Server 2008 R2, Server 2012 :3a. make the hidden directory C:\ProgramData visible3b. go to C:\ProgramData\Dialogic\HMP\cfgfor Windows XP, server 2003 and Server 2008 32bit :3a. go to C:\Program Files\Dialogic\cfgThen:4. Backup existing RtfConfigWin.xml,5. Replace it with attached RtfConfigWin.xml (unzip it first)6. Shutdown and restart Windows. 7. Start the Dialogic service.8. Once Dialogic service has fully started then start the VoiceGuide service. 9. .ZIP up Dialogic logs (C:\Program Files (x86)\Dialogic\log directory) 12. Please post all the above .ZIPed logs here. RtfConfigWin.zip Share this post Link to post
Guest ThaoHuynh Report post Posted 03/23/2017 05:09 AM This is all RTF log (C:\Program Files (x86)\Dialogic\HMP\log) log.zip Share this post Link to post
SupportTeam Report post Posted 03/23/2017 06:19 AM That trace still does not show us why this error is occurring: h3r_Start : caught unknown exception while creating Sharon Manager Most likely either a port is not available or there is some DLL mismatch or some anti-virus type software is interfering. Recommend to set up a system starting with a new reformatted disk/partition and install only Windows + HMP +VoiceGuide on that new system. As this is a HMP system you could use an ESXi VM for this purpose. Share this post Link to post
