Paths As $Rv
can you change VG to use variable in paths tab in script module?
instead
on {success} goto [external_crm_active_connecting]
on {fail} goto [external_crm_active_connecting]
this
"$RV[path_list in_module_name]"
where
$RV[path_list in_module_name] =
Looks like In current version this will work only for certain cases (eg. in Get Numbers module when reacting to entered DTMF strings).
In current version this will not work when looking for success/fail paths.
It should be an easy modification to make this approach work for all path types and modules. We will schedule this to be available in next release version.
