Guest ThaoHuynh Report post Posted 03/24/2017 02:42 AM Hi VoiceGuide Team, I have installed Dialogic HMP 3.0 drivers. But when i ran hpettool.exe to test for HPET compatability. It has errored. C:\Program Files (x86)\Dialogic\HMP\bin>hpettool.exe /t Failed to extract driver package. Failed to extract driver package. Error: Failed to execute the command. C:\Program Files (x86)\Dialogic\HMP\bin> System: Windows 7 Professional Service Pack 1, 64 bit. How can fix my problem? Thank you your help, Thao Huynh Share this post Link to post
SupportTeam Report post Posted 03/24/2017 04:09 AM Few things to try: Are you logged in as Administrator while running the hpettool.exe ? Is the "Command Prompt" and "Admin" version of Command Prompt ? As this is a 64 bit version of Windows then are you running the 64 bit version of the hpettool.exe ? Most newer systems support the HPET timer, so if you are using a current version motherboard and CPU then most likely the HPET timer is supported. You may need to confirm if it is enabled in BIOS however. Share this post Link to post
Guest ThaoHuynh Report post Posted 03/24/2017 04:59 AM I ran hpettool64 again and it's show "HPET is hardware & BIOS supported and is enabled on this system.". Does it work fine? Share this post Link to post
SupportTeam Report post Posted 03/24/2017 05:04 AM Yes, that confirms HPET is enabled on this system. Share this post Link to post
Guest ThaoHuynh Report post Posted 03/24/2017 07:03 AM Thank you so much Share this post Link to post
