Guest ThaoHuynh Report post Posted 04/21/2017 03:12 AM Hi VG team, I tried to test my script. When [Get Card Number] module asked caller to confirm card number, i pressed '2#'. But it didn't play to the end of sound file, and hang up automatically. Please check my script and vgEngine. Thank you for your help. log.zip Share this post Link to post
SupportTeam Report post Posted 04/21/2017 03:36 AM Just pressing "2" is enough to indicate that you want to re-enter the number. The "2" keypress takes you back to entering the number again. When you press "#" without any other number being entered beforehand then this will result in a "Fail" path being taken - as no number was entered. In your current script the "Fail" path is not defined in that module, so VoiceGuide hangs up the call. 094945.789 9 3 1 state [Get Card Number] Number Input 809 - confirming 094945.790 9 3 1 PlaySoundStartNumbers select (internal) C:\Program Files (x86)\VoiceGuide\system\voice\GetNbrsConfirmIntro.wav, C:\Program Files (x86)\VoiceGuide\system\voice\GetNbrsConfirmMenu.wav, 809, Digits ... 094954.069 22 3 1 ev dtmf 2 (134217729,50,10) iConferenceOtherLegLid=-1, iConferenceOtherLegIvrDevPort=0 ... 094954.070 9 3 1 state [Get Card Number] Number Input 094954.070 9 3 1 state [Get Card Number] Playing wav (PayGetCc.wav) 094954.070 9 3 1 play start ok, playId=616295 094954.820 22 3 1 ev dtmf # (134217729,35,10) iConferenceOtherLegLid=-1, iConferenceOtherLegIvrDevPort=0 094954.820 9 3 1 HangupCall qScr add (*# in LSGetNbrsPlayWelcMsg) crn_in=0, L1=Connected, L2=Running_Normal, lPlayId=616295, lRecId=0 Share this post Link to post
SupportTeam Report post Posted 04/21/2017 03:42 AM You can specify on {Fail} goto ... on {#} goto ... paths to better control what happens in your script when callers do not supply any numbers in that module. You could point the on {#} goto ... path back to the same module, so that if caller inadvertently presses the # before entering any numbers then the module will be restarted and caller will just get the "please enter numbers" prompt played to them again. Share this post Link to post
SupportTeam Report post Posted 04/21/2017 03:47 AM Also, trace shows that VoiceGuide is now registering itself as 17778140677@callcentric.com and that you are placing calls into that system from another phone registered with callcentric: 17778296701@callcentric.com 094226.364 9 voip registration data idx=0: SIP, server: callcentric.com, client: 17778140677@callcentric.com, alias: 17778140677@192.168.76.21, expires: 0, prefixes: , options: 094226.364 9 voip registration call. 094226.364 9 q_tel + cmd_VoIPProvider_Register 0 [0,0,0,0,0,0,0,0][SIP|callcentric.com|17778140677@callcentric.com|17778140677@192.168.76.21||||] 094237.950 9 3 1 state <offered> : cid=17778296701@callcentric.com , dnis=17778140677@callcentric.com connected So looks like this issue: http://voiceguide.com/forums/index.php?showtopic=12382 can now be closed? Can you advise how you resolved that callcentric->callcentric call issue that you were experiencing? Share this post Link to post
