Causes Isdn
Some versions need the cause tag to be surrounded by XML <cause></cause> tags,
eg: to have 'FACILITY_REJECTED' cause sent, assign this to the $RV[DropCall_CauseValue] :
<cause>FACILITY_REJECTED</cause>
This version now also allows specifying the case value by just setting $RV[DropCall_CauseValue] to the value itself, instead of using a tag.
This allows any value to be assigned, in cases where propriety codes need to be used.
[old link removed]
some tags codes have also been added.
The Help file entry: http://www.voiceguide.com/vghelp/source/html/modhangupcall.htm
has been updated accordingly.
