Brandon Report post Posted 03/08/2004 08:53 PM Team, Once someone leaves a voicemail and the system calls the "call forward" phone number. Is there a way to turn this feature on and off depending what time of day it is? Thanks. -Brandon Share this post Link to post
SupportTeam Report post Posted 03/08/2004 11:24 PM Yes. In the voicemail script's (see \system\vm\ directory) the forwarding of voicemail mesasges takes place when this command is called: VG.Vm_Event iLineId, "FORWARD", sVmbId, sVmLmRec, "", "" You just need to modify the VB Scripts to make sure this command will only be called during certian times. dStartTime = #11:00:00 AM# dEndTime = #6:00:00 PM# if Time >= dStartTime and Time <= dEndTime then 'OK to forward msg VG.Vm_Event iLineId, "FORWARD", sVmbId, sVmLmRec, "", "" end if To find all places from where the forwarding occurs its probably best to open all .VGS scripts in a text editor and then just to a text search for all occurrences of: "FORWARD" Share this post Link to post
