Script Modules
Hi VG Team,
I would like to use response result from web service.
ie: If result = 'a'
run module 'Say Card Number'
else
run module 'Enter Card Number'
How can i do that?
Thank you for your support.
Use an Evaluate Expression module.
The Web Service module will create a number of Result Variables ($RVs). Best to look at vgEngine trace to see what these are.
If you know the exact XML or JSON that the Web Service returns then you can deduce what $RVs are created, but best/easiest to just look in vgEngine trace after running a call to the Web Service.
Use the Evaluate Expression module to evaluate the $RV that you want to check the value of, and then set paths that match each value.
Say your Web Service module creates this $RV (amongst many others) :
$RV[MyWS_Report_Mode]
and the above $RV can have values aaaa or bbbb or something else.
then you would use this as expression to evaluate in the Evaluate Expression module (notice the quotes):
"$RV[MyWS_Report_Mode]"
and the paths would be:
on {aaaa} goto [say Card Number]
on {bbbb} goto [someModuleB]
on {True} goto [Enter Card Number]
Thank you so much.
I also have a issue in script module. Can VoiceGuide speak 3 random digits?
Use an 'Evaluate Expression' type module to evaluate this expression:
100 + Int(900*Rnd)
this will result in random number between 100 and 999.
The random number will be saved in $RV with the same name as the title of the Evaluate Expression module.
The $RV can then be used in a 'Say Numbers' type module to speak out the digits.
Use a Success or True path to go from the 'Evaluate Expression' type module to the 'Say Numbers' type module.
see vgEngine trace excerpt of a script doing this:
'Evaluate Expression' module was titled: GenerateSomeRnd
It created $RV[GenerateSomeRnd] that held the random number value, and the $RV[GenerateSomeRnd] was then played out by the Say Numbers module:
213304.349  11   5   1 state [GenerateSomeRnd] Evaluate [100 + Int(900*Rnd)]
213304.349  11   5   1       eval  [100 + Int(900*Rnd)]
213304.349  11   5   1       eval  InvokeMember Eval returned
213304.349  11   5   1       rvns  add   GenerateSomeRnd_Input|100 + Int(900*Rnd)
213304.349  11   5   1       rvns  add   GenerateSomeRnd|621
213304.349  11   5   1       Eval Expr result:[621]
213304.349  11   5   1       path {621} not found
213304.349  11   5   1       matching path not found [621], try boolean paths.
213304.349  11   5   1       ex: ScriptIo.VGMTYPE_EVALEXPR [621] could not be converted to boolean. Take Success path as string non-empty.
213304.349  11   5   1       FindNextVgmTitleInPathList: next module title is=[SayRnd]
213304.349  11   5   1       matching path found (Boolean True)
213304.349  11   5   1 t     timer clear (force=False)
213304.349  11   5   1       RunModule start
213304.349  11   5   1       RunModule start Say Numbers, [SayRnd], iModuleIdx=62, previous: vgm=61, vgs=2:2
213304.349  11   5   1       rv    replace start [$RV[GenerateSomeRnd]]
213304.349  11   5   1       rv    replace end   [621]
213304.349  11   5   1 state [SayRnd] Say Numbers: 621 as Digits
