Guest jerry Report post Posted 03/11/2003 03:33 AM I want record a message ,the record file name I hope use my define Variable name, how can I do it. Thanks very much! Share this post Link to post
SupportTeam Report post Posted 03/11/2003 06:07 AM Just specify the filename to record to using your Result Variable as part of the filename... If you have problems with this please post a copy of VoiceGuide's Event Trace which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
