Presale Questions - Part Deux
ok... I am down to 2 choices for software.... including yours...
I'd like to access either a database or spreadsheet.. compare the callerid to the database... then let my customer set up their own appointment... update the database, then email or fax a confirmation.
I think this is feasible...
do you have any sample script... to:
work with the spreadsheet or database?
and..
send an email... send a fax... (I suppose WinFax.. I think I saw some sample script on that... though... that script had a tiff file to fax if I remember...a process I may not be able to automate)?
and.. how I would pass variables (including data from the db) from one module to another...
thanks for your help
(my previous problem has been resolved... we will use the * to hangup from any menu... so we can pick up an extension)
another question re:subscripts... the Enterprise version is the only one that allows this? I see that a call was hung up in a subscript... I suppose I am using subscripts then? or could those have been internal??? this was using your voicemail server as a starting point
Please see the Help file's section on "DB Query" and "Run VB Script" modules.
Please see the Help file's section on "Send Email Message" and "Run VB Script" modules...
Please see the Help file's section on "Result Variables".
