health4us Report post Posted 03/10/2004 10:08 AM Can you add more than one attachement to the emails? Share this post Link to post
SupportTeam Report post Posted 03/10/2004 11:40 AM You should be able to specify multiple files, separating/delimiting each file in the list with a ";" character. Share this post Link to post
Guest Emre DURGUT Report post Posted 05/06/2004 06:23 AM Adding more than one attachment feature doesn't work. Did you fix this problem? Share this post Link to post
SupportTeam Report post Posted 05/09/2004 09:07 AM Please update the VG 5.2.1 install with attached .EXEs (overwriting existing) The .DLL file should be placed in Windows' System32 directory (overwriting existing). You will now be able to specify multiple attachments, using either a comma "," or a semicolon ";" as a delimiter between each filename. Before placing the DLL in Windows' System32 directory you should run the following command from a command prompt in that directory: regsvr32 -u vbsendmail.dll After placing the new DLL in Windows' System32 directory you should run the following command from a command prompt in that directory: regsvr32 vbsendmail.dll 040509_email_multiple_attachments_fix.zip Share this post Link to post
