More Than 1 Attachment
You should be able to specify multiple files, separating/delimiting each file in the list with a ";" character.
Adding more than one attachment feature doesn't work. Did you fix this problem?
Please update the VG 5.2.1 install with attached .EXEs (overwriting existing)
The .DLL file should be placed in Windows' System32 directory (overwriting existing).
You will now be able to specify multiple attachments, using either a comma "," or a semicolon ";" as a delimiter between each filename.
Before placing the DLL in Windows' System32 directory you should run the following command from a command prompt in that directory:
regsvr32 -u vbsendmail.dll
After placing the new DLL in Windows' System32 directory you should run the following command from a command prompt in that directory:
regsvr32 vbsendmail.dll
040509_email_multiple_attachments_fix.zip
