Are Result Variables Private To Each Line?
Hi VG team,
In case i have 2 lines and run the same script. And in this script i use Evaluate Expression module to counter the number of tries for each caller.
If i have 2 users call to my phone number in the same time. Can VG confuse about 2 counters?
Thank you for you support.
The counters (Result Variables) on different lines would be separate. Each counter (Result Variable) would keep data for its own line only.
Result Variables (RVs) are visible on the line on which they are created.
(an exception is if you were to create a 'Global' Result Variable. Global RVs are visible to all lines)
